coq-club - Re: [Coq-Club] Coq 8.2.1 and Proof General 3.7.1 are compatible?
chronological Thread
  • To: Benjamin Werner <benjamin.werner AT inria.fr>
  • Cc: Makarius <makarius AT sketis.net>, Gyesik Lee <gslee AT ropas.snu.ac.kr>, coq-club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Coq 8.2.1 and Proof General 3.7.1 are compatible?
  • Date: Wed, 22 Apr 2009 11:38:16 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type :content-transfer-encoding; b=dfn+9qVwJLPnQ9zNZvdo1W43kcBbJQD+Clfs8vJCJEYASuPFD9AfnhLiG2QdHb3mTI JAa+T0bGcw66qKxh1zFCKnO8WBCSJE+IdceJ0pttUXEFEBygvOTLLsYKvebyrzJGpGYn Cst6AxLNA/JFhHwF2J3X3bQZ59U/rgKdgprrM=
2009/4/21 Benjamin Werner
<benjamin.werner AT inria.fr>:
> With some emacs versions, this Coq/PG combination will only work
> if PG  is in V8.1 mode. But when
> one switches to V8.2, PG behaves as if it does not know how to handle 8.2
> and thus
> falls back into 8.0 mode.
Actually it falls back into v8.1 mode, unless coqtop -v says 8.0.
> On the Mac versions of emacs, this can break the
> undo
> command for instance.
> Try to add:
> (setq coq-version-is-V8-1 t)
This cannot hurt anyway, but it should generally not be necessary
unless you deal with several versions of coq.
Regards, Pierre
