coq-club - Re: [Coq-Club] Coq 8.2.1 and Proof General 3.7.1 are compatible?
chronological Thread
  • To: Gyesik Lee <gslee AT ropas.snu.ac.kr>
  • Cc: Benjamin Werner <benjamin.werner AT inria.fr>, Makarius <makarius AT sketis.net>, coq-club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Coq 8.2.1 and Proof General 3.7.1 are compatible?
  • Date: Wed, 22 Apr 2009 11:38:59 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type :content-transfer-encoding; b=IVNfNBp82mWRULVE9Y4OYNeuEfZuE+F57tCS5SEERuW86jEVxX8Pc0PbGa4S5LHXz9 ReiJ7P4AVdIx8LFWuZzZFOlVkmL0v94pbYy9s65OmRUUUitdA2/2ZvnIIG06/zti2CV1 CAtSVAU2PXrCj1zLemHISRz9l0zJhFX3sPrEM=
Hi,
2009/4/21 Gyesik Lee
<gslee AT ropas.snu.ac.kr>:
> O.k. now a strange thing happens.
> At starting up using "emacs test.v", it ends up with the following
> message in the command line of emacs (v. 21.4) in the buffer "test.v".
> "File mode specification error: (void-variable image-load-path)"
As MAkarius said, it is probably due to your old version of emacs.
This may be a problem because it suggests some part of PG files are
not loaded. Since PG seems to work, it must be a small part. Please
consider submit a bug report on
http://proofgeneral.inf.ed.ac.uk/trac/wiki.
> proofgeneral is in coq8.1 mode (to force another version, see for
> example C-h v 'coq-version-is-V8-0)'
> Coq default abbrevs loaded
> It seems that PG is  but activated, but not compatible with Coq 8.2.1. (??)
Yes it is. As there is no compatibilty problem between coq-8.1 and
coq-8.2, we did not add a specific v8.2 mode.  The message is an
information message for people dealing with several versions of coq at
the same time (pg guesses coq version by running coqtop -v and falls
in default mode if this fails).
> Yes I installed the tar file by hand. I just downloaded the tar file,
> unpacked and saved, then added the following line to .emacs:
> (load-file "~/ProofGeneral-3.7.1/generic/proof-site.el")
This is the right way to install PG.
> The Coq installation was very standard on a Debian linux server.
> Emacs version is 21.4.1
This is a bit old as Makarius said. On debian, I think emacs22 can
co-exist with emacs21 with no pain.
Regards
Pierre Courtieu
