- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Rewriting under abstractions
- Date: Mon, 4 May 2009 13:26:02 +0200
(* Dear all,
I have a theory which satisfies the axiom of extensionality (you may
just cut and paste this entire message into Coq):
Axiom extensionality: forall (A B : Set), forall (f g : A -> B),
(forall x : A, f x = g x) -> f = g.
(* I would like to use the axiom to automate rewriting under
lambda abstractions. To illustrate what I wish, suppose we
have a set with a binary operation and a neutral element: *)
Parameter A : Set.
Parameter op : A -> A -> A.
Parameter e : A.
Notation "x ** y" := (op x y) (at level 60, left associativity).
Axiom e_neutral_1: forall x, x ** e = x.
Axiom e_neutral_2: forall x, e ** x = x.
(* The two axioms function very nicely as simplification rules
and we add them to a database of rewrite hints. *)
Hint Rewrite e_neutral_1 e_neutral_2 : my_hints.
(* It is easy to prove the following: *)
Lemma foo: forall x y, x ** e ** y ** e ** e = x ** y.
Proof.
intros.
autorewrite with my_hints.
reflexivity.
Qed.
(* Now suppose we want to simplify something that appears inside a
lambda abstraction. We can still do it, but it's not as easy: *)
Lemma bar (f : (A -> A) -> A):
f (fun x => e ** x) = f (fun x => x ** e).
Proof.
intro f.
replace (fun x : A => e ** x) with (fun x : A => x ** e).
reflexivity.
apply extensionality.
intro x.
reflexivity.
Qed.
(* My question is how to write a tactic that will do an autorewrite
inside a lambda abstraction. Note that I am assuming the axiom of
extensionality, so this should be of some use.
As a test example, the tactic should automatically simplify
(fun x => e ** x ** e ** x) to (fun x => x ** x), even if it does
not succeed in proving the final goal in which such a term appears.
With kind regards,
Andrej
- [Coq-Club] Rewriting under abstractions, Andrej Bauer
- Re: [Coq-Club] Rewriting under abstractions,
Matthieu Sozeau
- Re: [Coq-Club] Rewriting under abstractions, Andrej Bauer
Matthieu Sozeau
