- To: aspiwack AT lix.polytechnique.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Add Relation sequence bisimilar
- Date: Mon, 04 May 2009 20:35:33 +0900 (JST)
Hello,
Thank you for the explanations.
> My suggestion would be as follows :
> - Streams (and generally coinductive types) should be defined something
> along the lines of :
> CoInductive Stream (A:Type) := { hd : A ; tl : Stream A }
I am specifically interested in colists, i.e., potentially infinite lists
with Nil and Cons constructors; records seem to me a less natural
representation for colists. What I imagine is something like:
CoInductive Colists (A:Type) := { hd : A ; tl : Option (Colists A) }
> - Do not use destruct or case or intros [ ] or whatever similar on a string
> object
When I deduce a coinductive property by coinduction,
I case analyze a coinductive object to get a constructor,
therefore to get a guarded coinduction. If I cannot move to records,
the absence of case and the likes sounds restrictive. Am I correct?
Kind regards,
Keiko
- Re: [Coq-Club] Add Relation sequence bisimilar, Arnaud Spiwack
- Re: [Coq-Club] Add Relation sequence bisimilar, Keiko Nakata
- Re: [Coq-Club] Add Relation sequence bisimilar, Eduardo Gimenez
Eduardo Gimenez
- RE: [Coq-Club] Add Relation sequence bisimilar,
Georges Gonthier
Keiko Nakata
Keiko Nakata
Georges Gonthier
