- From: Guilhem Moulin <guilhem.moulin AT ens-lyon.org>
- To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Mutual definition using a well-founded measure
- Date: Tue, 26 May 2009 17:52:27 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:date:from:to:cc:subject:message-id:mail-followup-to :references:mime-version:content-type:content-disposition :in-reply-to:user-agent; b=mLhJnaWXNm8onZbrLT7XdMc9OS4Q15swjcw7u+OCPDbAEz3fgLS+2eHzC0JxYykuKC nWfU7RX8T3aAEQxHXnNSUsHrfV9QrINT7G7Ez17pdcT1jWP+Dm0Fkx3wBKrRMWoBSr9H UdqSd2nVzor0AKZGRa+P28Ha9P4klNfORR2KE=
I didn't know it, thanks!
As attachment is the hint Yves just gave me
Guilhem.
On Tue, 26 May 2009 at 17:33:57 +0200, Stéphane Lescuyer wrote:
> Nothing's impossible but certainly, it won't happen overnight :) In
> the meanwhile, you might be interested in this work by Arthur
> Charguéraud :
> http://www.chargueraud.org/arthur/research/2009/fixwf/
> In particular, his fixpoint library has some support for
> mutually-recursive functions.
> HTH,
> Stéphane L.
--- Begin Message ---You could define a single function using a sum-type as input, with the various alternative in the input
- To: Guilhem Moulin <guilhem.moulin AT ens-lyon.org>
- Date: Tue, 26 May 2009 17:16:50 +0200
- Authentication-results: mx.google.com; spf=neutral (google.com: 140.77.166.68 is neither permitted nor denied by best guess record for domain of Yves.Bertot AT sophia.inria.fr) smtp.mail=Yves.Bertot AT sophia.inria.fr
corresponding to the various functions you wish to define recursively. This works well in your case,
because the output of the two mutually recursive functions are in the same type.
Inductive inpt : Type :=
g_arg (c:nat*list nat) | f_arg (c:nat*list nat).
Function h(x:inpt) : nat :=
match x with
f_arg c =>
match fst c with
| 0 => 0
| S n => h(f_arg (n, snd c)) + h(g_arg(n, snd c))
end
| g_arg c =>
match snd c with
| nil => 0
| a::l => h(f_arg(fst c, l)) + h(g_arg (fst c, l))
end
end.
Definition f c = h (f_arg c).
Definition g c = h (g_arg c).
You should be able to prove the expected equations for f and g.
When the output types are different, it becomes slightly more complex,
but it should still be possible, although you will have to come back to
basic well-founded induction.
Here is an example:
f (x:nat) = match x with 0 => 0 | S p => Zabs_nat (2+(g (Z_of_nat p)))
with
g (x:Z) = if Z_le_dec x 0 then 0%Z else Z_of_nat (2 + f (Zabs_nat (x - 1)))
These functions should be definable with:
Inductive inp2 : Type :=
f2_arg (x:nat) | g2_arg (x:Z).
Definition type_f (x:inp2) := match x with f2_arg _ => nat | g2_arg _ => Z end.
Definition inp2_nat (x:inp2) := match x with f2_arg n => n | g2_arg z => Zabs_nat z end.
Lemma l1 : forall x, (0 < x)%Z -> inp2_nat (f2_arg (Zabs_nat (x-1))) < inp2_nat (g2_arg x).
Admitted.
Lemma l2 : forall x, inp2_nat (g2_arg (Z_of_nat x)) < inp2_nat (f2_arg (S x)).
Admitted.
Now, with these lemmas you should be able to define h2 so that it captures the combined
behavior of f and g. I have to leave now, but I will complete the development later.
Yves
Yves
--- End Message ---
signature.asc
Description: Digital signature
- [Coq-Club] Mutual definition using a well-founded measure, Guilhem Moulin
- Re: [Coq-Club] Mutual definition using a well-founded measure,
Yves Bertot
Guilhem Moulin
Stéphane Lescuyer
- Re: [Coq-Club] Mutual definition using a well-founded measure, Guilhem Moulin
Benoit Razet
Benoit Razet
Stéphane Lescuyer
Guilhem Moulin
- Re: [Coq-Club] Mutual definition using a well-founded measure, muad
- Re: [Coq-Club] Mutual definition using a well-founded measure, harke
Yves Bertot
