- To: Guilhem Moulin <guilhem.moulin AT ens-lyon.org>, St�pha ne Lescuyer <stephane.lescuyer AT inria.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Mutual definition using a well-founded measure
- Date: Tue, 26 May 2009 18:13:43 +0200
You can use also Fixpoint with the ad-hoc predicate technique and a
well-founded relation.
The extra argument used for ensuring the termination will be erased at
extraction.
The following Coq listing may be scary looking compared to the original one...
Require Import List.
Require Import Plus.
Definition pif (c:nat*list nat) := fst c + length (snd c).
(* relation for successor, the well-foundedness of this relation will be
used. *)
Definition Rnat (n' n : nat) : Prop := n = S n'.
Lemma dom_inv1 : forall c n l n',
Acc Rnat (pif c) ->
c = (n, l) ->
n = S n' -> Acc Rnat (pif (n',l)).
Proof.
intros c n l n' P eq eq1.
rewrite eq in P. rewrite eq1 in P. unfold pif in P. simpl in P.
unfold pif. simpl.
assert (P1 : Rnat (n' + length l) (S (n' + length l))).
unfold Rnat. reflexivity.
exact (Acc_inv P _ P1).
Defined.
Lemma dom_inv2 : forall c n l a l',
Acc Rnat (pif c) ->
c = (n, l) ->
l = (a :: l') -> Acc Rnat (pif (n,l')).
Proof.
intros c n l a l' P eq eq1.
unfold pif. simpl.
generalize (plus_Snm_nSm n (length l')).
intro L. rewrite <- L in P.
assert (P1 : Rnat (n + length l') (S (n + length l'))).
Defined.
Fixpoint f (c:nat*list nat) (h : Acc Rnat (pif c)) {struct h} : nat :=
match c as c1 return c = c1 -> nat with
| (n,l) => fun eq =>
match n as n1 return n = n1 -> nat with
| 0 => fun eq1 => 0
| S n' => fun eq1 =>
f (n', l) (dom_inv1 c n l n' h eq eq1) + g (n', l) (dom_inv1 c n l n'
h eq eq1)
end (refl_equal n)
end (refl_equal c)
with g (c:nat*list nat) (h : Acc Rnat (pif c)) {struct h} : nat :=
| (n,l) => fun eq =>
match l as l1 return l = l1 -> nat with
| nil => fun eq1 => 0
| a :: l' => fun eq1 =>
f (n, l') (dom_inv2 c n l a l' h eq eq1) + g (n, l') (dom_inv2 c n l
a l' h eq eq1)
end (refl_equal l)
end (refl_equal c).
Guilhem Moulin wrote:
I didn't know it, thanks!
As attachment is the hint Yves just gave me
Guilhem.
On Tue, 26 May 2009 at 17:33:57 +0200, Stéphane Lescuyer wrote:
Nothing's impossible but certainly, it won't happen overnight :) In
the meanwhile, you might be interested in this work by Arthur
Charguéraud :
http://www.chargueraud.org/arthur/research/2009/fixwf/
In particular, his fixpoint library has some support for
mutually-recursive functions.
HTH,
Stéphane L.
Subject:
Yves Bertot
<Yves.Bertot AT sophia.inria.fr>
Date:
Tue, 26 May 2009 17:16:50 +0200
To:
Guilhem Moulin
To:
Guilhem Moulin
You could define a single function using a sum-type as input, with the various alternative in the input
corresponding to the various functions you wish to define recursively. This works well in your case,
because the output of the two mutually recursive functions are in the same type.
Inductive inpt : Type :=
g_arg (c:nat*list nat) | f_arg (c:nat*list nat).
Function h(x:inpt) : nat :=
match x with
f_arg c =>
match fst c with
| 0 => 0
| S n => h(f_arg (n, snd c)) + h(g_arg(n, snd c))
end
| g_arg c =>
match snd c with
| nil => 0
| a::l => h(f_arg(fst c, l)) + h(g_arg (fst c, l))
end
end.
Definition f c = h (f_arg c).
Definition g c = h (g_arg c).
You should be able to prove the expected equations for f and g.
When the output types are different, it becomes slightly more complex,
but it should still be possible, although you will have to come back to
basic well-founded induction.
Here is an example:
f (x:nat) = match x with 0 => 0 | S p => Zabs_nat (2+(g (Z_of_nat p)))
with
g (x:Z) = if Z_le_dec x 0 then 0%Z else Z_of_nat (2 + f (Zabs_nat (x - 1)))
These functions should be definable with:
Inductive inp2 : Type :=
f2_arg (x:nat) | g2_arg (x:Z).
Definition type_f (x:inp2) := match x with f2_arg _ => nat | g2_arg _ => Z end.
Definition inp2_nat (x:inp2) := match x with f2_arg n => n | g2_arg z => Zabs_nat z end.
Lemma l1 : forall x, (0 < x)%Z -> inp2_nat (f2_arg (Zabs_nat (x-1))) < inp2_nat (g2_arg x).
Admitted.
Lemma l2 : forall x, inp2_nat (g2_arg (Z_of_nat x)) < inp2_nat (f2_arg (S x)).
Admitted.
Now, with these lemmas you should be able to define h2 so that it captures the combined
behavior of f and g. I have to leave now, but I will complete the development later.
Yves
Yves
- [Coq-Club] Mutual definition using a well-founded measure, Guilhem Moulin
- Re: [Coq-Club] Mutual definition using a well-founded measure,
Yves Bertot
Guilhem Moulin
Stéphane Lescuyer
Guilhem Moulin
- Re: [Coq-Club] Mutual definition using a well-founded measure, Benoit Razet
- Re: [Coq-Club] Mutual definition using a well-founded measure, Guilhem Moulin
Guilhem Moulin
Stéphane Lescuyer
Guilhem Moulin
- Re: [Coq-Club] Mutual definition using a well-founded measure, muad
- Re: [Coq-Club] Mutual definition using a well-founded measure, harke
Yves Bertot
