- To: Neil Ghani <Neil.Ghani AT cis.strath.ac.uk>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] (no subject)
- Date: Mon, 22 Jun 2009 07:49:35 -0400
Neil Ghani wrote:
1. I've been trying to write down an induction principle for the initial algebra of any functor, ie type operator with map operation. I know Coq generates induction principles for some functors and I wondered if it can generate an induction principle for any functor or if there are limitations on the class of functors for which induction principles can be generated.
2. What are the principles underlying the induction principles Coq generates? I believe they are added as axioms every time an inductive data type is declared. Do they just look right or are they proven to be correct in a mathematical sense? If the later, could I get a response with a reference please?
I hope my answer to #2 sheds light on the issues behind #1.
No, no axioms are added. Induction principle generation is only a convenience; each principle is a recursive function definition in CIC. After writing an inductive definition for type [foo], try running [Print foo_ind.]. Some inductive types have useful principles that aren't generated automatically; for instance, mutually-inductive types (which the [Scheme] command handles) and nested types (like inductive types [T] defined in terms of [list T], for which it's helpful to manually define a principle in terms of a predicate that describes when another predicate holds of every element of a list).
So now I guess I do get to answering #1: the limitations on induction come directly from the validity rules for recursive function definitions. I'm not sure of the best reference to a definitive treatment of the formal rules. The Coq manual tries to give an intuition, at least, of which definitions are accepted.
- [Coq-Club] (no subject), Neil Ghani
- Re: [Coq-Club] (no subject), Adam Chlipala
- Re: [Coq-Club] automatically generated induction principles, Lionel Elie Mamane
