coq-club - Re: [Coq-Club] Setoids on dependently typed functions?
chronological Thread
  • To: Adam Koprowski <adam.koprowski AT gmail.com>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Setoids on dependently typed functions?
  • Date: Mon, 22 Jun 2009 17:27:40 -0400
Hi again,
Actually, I sent this a bit too quickly. There was a simple fix to
make this work if the dependent arguments stay unchanged. It's in
the trunk. I'm not sure that unification will always be good enough
with signatures using [forall_relation] though.
Cheers,
-- Matthieu
Le 22 juin 09 à 16:47, Matthieu Sozeau a écrit :
Le 22 juin 09 à 15:13, Adam Koprowski a écrit :
  Dear all,
 I'm trying to define a setoid equality on vectors given a setoid
equality on vector elements. However, I'm having troubles properly
declaring morphisms for vector operations. It seems to me that the
problem has to do with declaring morphisms on dependently typed
functions, however I'd appreciate a comment on whether I'm doing
something wrong or just hitting a setoid limitation and if so, whether
there is a work-around. Let me illustrate what I have in mind on a
simple example.
Hi Adam, you are indeed hitting a setoid limitation. While there is
primitive setup for building signatures of dependent functions, it is
not currently supported by the setoid tactics. The only workaround is
to put the dependent arguments at the beginning of the type like you
did, if possible. Then they are treated like parameters. If some
dependent arguments appear after some arguments you want to rewrite,
you should build a dependent signature like this:
Add Parametric Morphism A (eqA : Setoid A) n : (@Vnth A n)
 with signature equiv ==> forall_relation (fun i => eq ==> equiv)
   as Vnth_morph2.
But the treatment of dependent morphisms is not implemented yet.
I'm pretty sure it can be done though, I'm working on it.
(* Setoid equality on [A] yields a setoid on [vector A] *)
(* [?] Do we need to declare both the relation and a type-class instance?
If I omit this declaration then the constraints for the following
      parametric morhism fail... *)
Program Instance vec_equality `(eqA : Setoid A) : Setoid (vector A n) :=
 { equiv := @eq_vec A eqA n; setoid_equiv := _ }.
That's because [equiv] is defined on [Setoid] not [Equivalence], and we don't
have an instance of [Equivalence -> Setoid], it would loop with the existing
[Setoid -> Equivalence] projection.
Hope this helps,
-- Matthieu
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
        http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
