- To: Matthieu Sozeau <mattam AT mattam.org>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Setoids on dependently typed functions?
- Date: Tue, 23 Jun 2009 10:22:24 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :cc:content-type; b=Awq8LNTa8uQQIrMSujwW4kIJhtMwoucz/P4wUSMB8OoswgLZ+DhX4Uno6hTm+uQefo y1fKGUYsFaZF35zXyqTryD6PgCWKKU6mKMo0Lu0g0s3SO65gdZ5Cp8C2oMOb9xv3jhbV b7wvDIJwWvBFzxKh8WRTJlSmVJ/f0N265QaHE=
Dear Matthieu,
Thanks a lot for your prompt and helpful response. I'll follow your suggestions and see how things are after updating to the trunk.
Cheers,
Adam
On Mon, Jun 22, 2009 at 23:27, Matthieu Sozeau <mattam AT mattam.org> wrote:
Hi again,
Actually, I sent this a bit too quickly. There was a simple fix to
make this work if the dependent arguments stay unchanged. It's in
the trunk. I'm not sure that unification will always be good enough
with signatures using [forall_relation] though.
Cheers,
-- Matthieu
Adam.Koprowski AT gmail.com, http://www.cs.ru.nl/~Adam.Koprowski
The difference between impossible and possible
lies in determination (Tommy Lasorda)
- [Coq-Club] Setoids on dependently typed functions?, Adam Koprowski
- Re: [Coq-Club] Setoids on dependently typed functions?,
Matthieu Sozeau
Matthieu Sozeau
- Re: [Coq-Club] Setoids on dependently typed functions?, Adam Koprowski
Matthieu Sozeau
Matthieu Sozeau
