- From: Arnaud Spiwack <Arnaud.Spiwack AT lix.polytechnique.fr>
- To: Edsko de Vries <edskodevries AT gmail.com>
- Cc: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Compile failure on Mac OS X
- Date: Thu, 09 Jul 2009 21:20:07 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:message-id:date:from:user-agent:mime-version:to:cc:subject :references:in-reply-to:content-type:content-transfer-encoding; b=LzBGJHAu/sa6I6GR4JbOB7z0LtvmN+gG1CR/6D+j1AUm/bndoXCFvFyWa9VdtNG/G7 KfnGWazWe9I5yCxKPI6sSV/2QL2hLs4M4x2K7HbO4ci+mXFkza6fh97oIRrkWNYehQEC 2hn5sFwmo+Y9UDR0Pvwuf0GXcaf37Ae9lFTco=
It might be that you haven't compiled camlp5 in --transitional mode.
PS : test.ml4 is a blank filed used to test that the camlp5 grammar doesn't go kaboom.
Arnaud
Edsko de Vries a écrit :
Hi,
I'm trying to compile Coq 8.2pl1 on Mac OS X (10.5.7) and am getting an error during compilation. I've configured it using
./configure -local -fsets basic -reals basic -coqide no -with-doc no -debug
(Also tried with -opt option, with same result). Running make world stops with
CAMLP4DEPS test.ml4
Testing parsing/grammar.cma
Error while loading "config/coq_config.cmo": config/coq_config.cmo is not a bytecode object file.
File "test.ml4", line 1, characters 0-1:
Error: Preprocessor error
make[1]: *** [parsing/grammar.cma] Error 2
make: *** [stage1] Error 2
(The corresponding verbose output is at the end of this mail). The file config/coq_config.cmo does exist, and 'file' returns:
# file config/coq_config.cmo
config/coq_config.cmo: Objective caml object file (.cmo) (Version 007).
Interestingly, simply removing this file gives the exact same error (?).
Ocaml itself is installed through macports:
# ocaml -version
The Objective Caml toplevel, version 3.11.1
# camlp5 -v
Camlp5 version 5.11 (ocaml 3.11.0)
I thought that maybe the camlp5 version was the problem (although I managed to compile Coq on a different machine, also running Mac OS X, with the same versions of ocamlc and camlp5 -- not sure what the differences between the two machines are, except that the machine on which it worked is an old PowerPC PowerBook and the machine on which it breaks is a much newer Intel iBook :-/ ), so I installed the latest version of 5.12 manually:
# camlp5 -v
Camlp5 version 5.12 (ocaml 3.11.1)
Compilation (starting from a clean slate) now gives a different error message:
CAMLP4DEPS test.ml4
Error while loading "parsing/argextend.cmo": interface mismatch on Pcaml.
I'm not Ocaml user so I'm stuck here. Any hints?
Thanks,
Edsko
PS. Verbose output: with campl5 version 5.11:
# make VERBOSE=1 world
****************** Entering stage1 ******************
make -f Makefile.stage1 "stage1"
"ocamlc" -rectypes -I config -I tools -I tools/coqdoc -I scripts -I lib -I kernel -I kernel/byterun -I library -I proofs -I tactics -I pretyping -I interp -I toplevel -I parsing -I ide/utils -I ide -I contrib/omega -I contrib/romega -I contrib/micromega -I contrib/ring -I contrib/dp -I contrib/setoid_ring -I contrib/xml -I contrib/extraction -I contrib/interface -I contrib/fourier -I contrib/cc -I contrib/funind -I contrib/firstorder -I contrib/field -I contrib/subtac -I contrib/rtauto -I "+camlp5" -g -pp "camlp5o -I . config/coq_config.cmo lib/pp_control.cmo lib/pp.cmo lib/compat.cmo lib/flags.cmo lib/util.cmo lib/bigint.cmo lib/dyn.cmo lib/hashcons.cmo lib/predicate.cmo lib/rtree.cmo lib/option.cmo kernel/names.cmo kernel/univ.cmo kernel/esubst.cmo kernel/term.cmo kernel/mod_subst.cmo kernel/sign.cmo kernel/cbytecodes.cmo kernel/copcodes.cmo kernel/cemitcodes.cmo kernel/declarations.cmo kernel/retroknowledge.cmo kernel/pre_env.cmo kernel/cbytegen.cmo kernel/conv_oracle.cmo kernel/environ.cmo kernel/closure.cmo kernel/reduction.cmo kernel/type_errors.cmo kernel/entries.cmo kernel/modops.cmo kernel/inductive.cmo kernel/typeops.cmo kernel/indtypes.cmo kernel/cooking.cmo kernel/term_typing.cmo kernel/subtyping.cmo kernel/mod_typing.cmo kernel/safe_typing.cmo library/nameops.cmo library/libnames.cmo library/summary.cmo library/nametab.cmo library/libobject.cmo library/lib.cmo library/goptions.cmo library/decl_kinds.cmo library/global.cmo pretyping/termops.cmo pretyping/evd.cmo pretyping/reductionops.cmo pretyping/inductiveops.cmo pretyping/rawterm.cmo pretyping/detyping.cmo pretyping/pattern.cmo interp/topconstr.cmo interp/genarg.cmo interp/ppextend.cmo proofs/tacexpr.cmo parsing/lexer.cmo parsing/extend.cmo toplevel/vernacexpr.cmo parsing/pcoq.cmo parsing/q_util.cmo parsing/q_coqast.cmo parsing/argextend.cmo parsing/tacextend.cmo parsing/vernacextend.cmo parsing/g_prim.cmo parsing/g_tactic.cmo parsing/g_ltac.cmo parsing/g_constr.cmo -impl" -impl test.ml4 -o test-grammar
and with version 5.12:
"ocamlc.opt" -rectypes -I config -I tools -I tools/coqdoc -I scripts -I lib -I kernel -I kernel/byterun -I library -I proofs -I tactics -I pretyping -I interp -I toplevel -I parsing -I ide/utils -I ide -I contrib/omega -I contrib/romega -I contrib/micromega -I contrib/ring -I contrib/dp -I contrib/setoid_ring -I contrib/xml -I contrib/extraction -I contrib/interface -I contrib/fourier -I contrib/cc -I contrib/funind -I contrib/firstorder -I contrib/field -I contrib/subtac -I contrib/rtauto -I "+camlp5" -g -pp "camlp5o -I . config/coq_config.cmo lib/pp_control.cmo lib/pp.cmo lib/compat.cmo lib/flags.cmo lib/util.cmo lib/bigint.cmo lib/dyn.cmo lib/hashcons.cmo lib/predicate.cmo lib/rtree.cmo lib/option.cmo kernel/names.cmo kernel/univ.cmo kernel/esubst.cmo kernel/term.cmo kernel/mod_subst.cmo kernel/sign.cmo kernel/cbytecodes.cmo kernel/copcodes.cmo kernel/cemitcodes.cmo kernel/declarations.cmo kernel/retroknowledge.cmo kernel/pre_env.cmo kernel/cbytegen.cmo kernel/conv_oracle.cmo kernel/environ.cmo kernel/closure.cmo kernel/reduction.cmo kernel/type_errors.cmo kernel/entries.cmo kernel/modops.cmo kernel/inductive.cmo kernel/typeops.cmo kernel/indtypes.cmo kernel/cooking.cmo kernel/term_typing.cmo kernel/subtyping.cmo kernel/mod_typing.cmo kernel/safe_typing.cmo library/nameops.cmo library/libnames.cmo library/summary.cmo library/nametab.cmo library/libobject.cmo library/lib.cmo library/goptions.cmo library/decl_kinds.cmo library/global.cmo pretyping/termops.cmo pretyping/evd.cmo pretyping/reductionops.cmo pretyping/inductiveops.cmo pretyping/rawterm.cmo pretyping/detyping.cmo pretyping/pattern.cmo interp/topconstr.cmo interp/genarg.cmo interp/ppextend.cmo proofs/tacexpr.cmo parsing/lexer.cmo parsing/extend.cmo toplevel/vernacexpr.cmo parsing/pcoq.cmo parsing/q_util.cmo parsing/q_coqast.cmo parsing/argextend.cmo parsing/tacextend.cmo parsing/vernacextend.cmo parsing/g_prim.cmo parsing/g_tactic.cmo parsing/g_ltac.cmo parsing/g_constr.cmo -impl" -impl test.ml4 -o test-grammar
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Compile failure on Mac OS X, Edsko de Vries
- Re: [Coq-Club] Compile failure on Mac OS X,
Yves Bertot
- Re: [Coq-Club] Compile failure on Mac OS X, Edsko de Vries
- Re: [Coq-Club] Compile failure on Mac OS X, Arnaud Spiwack
- Message not available
Yves Bertot
