coq-club - Re: [Coq-Club] Compile failure on Mac OS X
chronological Thread
  • To: hugo.herbelin AT inria.fr
  • Cc: coq-club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Compile failure on Mac OS X
  • Date: Mon, 13 Jul 2009 13:33:01 +0100
Hi Hugo,
Thanks for your help.
If not already done, can you try calling configure with option
"-camlp5dir /Users/wendy/csw/lib/ocaml/camlp5" and check that the
output line mentioning Camlp4 says
Ah, that did the trick. The original output of configure was simply
  Camlp4 library in                 : +camlp5
which is why I didn't cop on that it was using the wrong camlp5 (I made sure that the new camlp5 was first in my PATH, so I figured that would be sufficient).
It's working now.
Thanks again,
Edsko
