coq-club - Re: [Coq-Club] Productivity and well-definedness
chronological Thread
  • To: Edsko de Vries <edskodevries AT gmail.com>
  • Cc: coq-club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Productivity and well-definedness
  • Date: Tue, 18 Aug 2009 17:27:55 +0200
In my opinion, your 'leaves' function exists in a world just slightly beyond pure Coq, but not beyond HOL,
for instance.
let us consider the following function of type nat -> cotree -> nat
Fixpoint f (n:nat)(t:cotree) : nat :=
 match n with
   0 => 0
 | S p =>
   match t with
     coleaf => 1
   | cobranch t1 t2 => f p t1 + f p t2
   end
 end.
This is a plain structural recursive function in n. Given a cotree t, you can consider the sequence
 fun x => f x t
I believe it must be fairly easy to show that this sequence is always increasing.
Using the excluded-middle axiom, you can reason on whether this sequence is bound or whether it goes to infinity, using Hilbert's choice operator you can use this to define a function of type cotree -> option nat,
where None would be used to represent infinity. The axiom for excluded middle and Hilbert's choice operator are provided in HOL's theory.
You could probably also model the 'leaves' function inside Coq augmented with ClassicalEpsilon.
Yves
