- From: Arnaud Spiwack <Arnaud.Spiwack AT lix.polytechnique.fr>
- To: Edsko de Vries <edskodevries AT gmail.com>
- Cc: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Productivity and well-definedness
- Date: Tue, 18 Aug 2009 21:52:05 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:message-id:date:from:user-agent:mime-version:to:cc:subject :references:in-reply-to:content-type:content-transfer-encoding; b=p6k/wXOPReAEFELscUEPagZdFYTHzJF1J7nCj+hxPvlcDCyCWw22evFxZyhrRQjJoa ZQqCk3jlNzCMorryrmocHj593kUp+g6ynOo2QSRnGfT8HqAvXdRLMX6FiyREAUU6SRUX 8mWKVptclEsyg2a1qfT7t07tOQa/iCVktBC24=
Well, you do not need to go all the way to classical functional relations to be able to build this function. You need only one niceo function : one that decides whether a function from cotree to conat terminates (that is a halting problem oracle). These are hard to find in nature. But if you are given one, it's quite easy to compute the "number" of leaves in your cotree.
That said, you cannot tell that to Coq, because it is not able to meta-reason on termination.
But still, it's rather easy a function to build, you only need to be able to look at the omega-th step. We could say it almost exists. Some people like to say it has a low turing degree.
Arnaud Spiwack
Edsko de Vries a écrit :
Hi,
I am a programmer at heart which is why I feel very comfortable with proofs in Coq. Notions such as termination and productivity make sense to me; domain-theoretic definitions of functions as least or greatest fixed points -- I have to think about a lot more.
Now, my "programmatic" (am I allowed say "constructive"?) intuition usually serves me quite well. Simple example: when a function "obviously does not terminate", it should not be possible to give an inductive definition of the function (it would not be well-founded).
My question is this: when a function is "obviously not productive", does that mean it should not be possible to give an coinductive definition of that function (it would be ill-specified in some sense, although I'm not sure what the equivalent of "well-founded" is for coinduction)?
Example: suppose we define coinductive trees as
CoInductive cotree : Set :=
| coleaf : cotree
| cobranch : cotree -> cotree -> cotree.
Consider a function to count the number of leaves in a tree
leaves : cotree -> conat
(the domain is conat because there might be infinitely many leaves). This function is "obviously not productive": there are infinitely large trees that don't have any leaves but simply keep on branching forever. For trees like this, the expected answer is zero (there are no leaves in the tree) or possibly infinity (one might argue that that is a valid interpretation) but for either answer the function would have to be sure that the tree is infinite and does not have any leaves; it needs to traverse the entire tree before it can be sure and so cannot produce (even part of) the answer in finite time. Hence, this function is not productive.
However, what does that mean? Does 'leaves' exist in some mathematical world that I simply cannot encode in Coq, or is it somehow inhererently ill-specified?
Thanks,
Edsko
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Productivity and well-definedness, Edsko de Vries
- Re: [Coq-Club] Productivity and well-definedness,
Adam Chlipala
- Re: [Coq-Club] Productivity and well-definedness, Edsko de Vries
- Re: [Coq-Club] Productivity and well-definedness, Yves Bertot
- Re: [Coq-Club] Productivity and well-definedness, Thorsten Altenkirch
- Re: [Coq-Club] Productivity and well-definedness, Arnaud Spiwack
Adam Chlipala
