- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Mixing induction and coinduction
- Date: Mon, 14 Sep 2009 16:02:41 +0200
muad a écrit :
I just did one of less than 200 loc (but the very specific part is about 130 loc):
Taral wrote:
On Thu, Aug 27, 2009 at 7:54 AM, Celia
Picard<celia.picard AT irit.fr>
wrote:
(* By the way, we have a proof of injectivity of Fin that looks a bitNot really. Any such proof of type equivalence would necessarily
complicated.
Is there a well-known (easier) proof of Fin n = Fin m -> n = m ? *)
involve proving things about the cardinality of Fin n and Fin m by
example.
Taral
<taralx AT gmail.com>
"Please let me know if there's any further trouble I can give you."
-- Unknown
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
My proof of this Fin injectivity is the culmination of about 500 line script
using pigeonhole principle, I assume you have something similar?
Set Implicit Arguments.
Inductive SFalse : Set :=.
Definition not_nul n : Set :=
match n with
| 0 => SFalse
| S _ => unit
end.
Inductive Fin : nat -> Set :=
| first : forall n, Fin (S n)
| succ : forall n, Fin n -> Fin (S n).
Inductive head card ord :=
| Fh : ord = first card -> head card ord
| Sh : forall x, ord = succ x -> head card ord.
Definition decompose card (ord : Fin (S card)) : head ord :=
match
ord as f in (Fin n)
return
(match n as u0 return (Fin u0 -> Set) with
| 0 => fun _ : Fin 0 => SFalse
| S k => fun H0 : Fin (S k) => head H0
end f)
with
| first n => Fh (refl_equal (first n))
| succ n H0 => Sh (refl_equal (succ H0))
end.
Ltac decomp x :=
let e := fresh in
let y := fresh x in
destruct (decompose x) as [e|y e];
rewrite e in *; clear e x.
Definition noset (fn : Fin 0) : SFalse :=
match fn in (Fin n) return not_nul n with
| first _ => tt
| succ _ _ => tt
end.
Ltac no_set x :=
destruct (noset x).
Fixpoint depth n (fn : Fin n) :=
match fn with
| first _ => 0
| succ _ m => S (depth m)
end.
(** The following lemma states that two values of [Fin m] are the same iff
they have same depth *)
Lemma depth_eq : forall m (fm fn : Fin m), depth fm = depth fn -> fm = fn.
Proof.
induction fm; intros fn H; decomp fn; simpl in *; inversion H; auto.
rewrite IHfm with fn0; auto.
Qed.
(** The following lemma is an inversion principle for [Fin m];
funny remark: the proof uses depth_eq as I didn't find better proof *)
Lemma succ_inversion : forall m (fm fn : Fin m), succ fm = succ fn -> fm = fn.
Proof.
intros.
assert (depth (succ fm) = depth (succ fn)).
rewrite H; auto.
inversion H0.
apply depth_eq; auto.
Qed.
Definition nat_eq : forall (m n : nat), {m=n}+{m<>n}.
decide equality.
Qed.
Definition Fin_eq : forall m (fm fn : Fin m), {fm=fn}+{fm<>fn}.
Proof.
intros.
destruct (nat_eq (depth fm) (depth fn)).
left; apply depth_eq; auto.
right; intro H; destruct n; rewrite H; auto.
Qed.
(** The following structure is quite weird:
[@at_least
set n P] means that [set] contains at least n elements;
for any [v] in [set], [P v] implies that v is not one of the considered
elements *)
Inductive at_least (A : Set) : nat -> (A -> Prop) -> Prop :=
| Nothing : forall (P : A -> Prop),
at_least 0 P
| Something : forall x card P (Q : A -> Prop) (l : at_least card P),
P x -> (forall y, Q y -> (x<>y /\ P y)) ->
at_least (S card) Q.
Lemma at_least_card :
forall card, exists notin : Fin card -> Prop, at_least card notin.
Proof.
induction card.
(* The case when [card] is 0 is trivial *)
exists (fun _ => True); apply Nothing.
(* The case where [card] is [S card'] is a lot more complex *)
destruct IHcard;
set (P_ := fun (K : Prop) card x (y : Fin (S card)) =>
match decompose y with Fh _ => K|Sh H _ => x H end).
(* we assume that we can build a "not in" property without
using [first card']*)
cut (at_least card (P_ True card x)).
(* now we have to add [first card'] *)
clear H; intro; exists (P_ False card x);
apply Something with (first card) (P_ True card x);
subst P_; simpl; auto; intros.
(* and to check it is not in the set *)
decomp y; simpl; auto; intuition; discriminate H1.
(* now we prove our assumption by induction,
but before running into it, we must isolate
[card'] which is not part of the induction *)
revert H; set (t := card) at 2 4; generalize t;
subst t; intros.
(* here begin our induction *)
induction H.
(* the trivial case *)
apply Nothing.
(* the other (not too hard) case *)
apply Something with (succ x) (P_ True card P);
simpl; auto.
clear IHat_least H; intros; subst P_; simpl in *.
(* we use the fact we have build our set
without using [first] *)
decomp y.
intuition; discriminate H2.
destruct (H1 _ H); clear H1 H.
intuition; apply H2; apply succ_inversion; auto.
Qed.
Lemma at_most_card : forall n m (notin : Fin m -> Prop),
at_least (m + 1 + n) notin -> False.
Proof.
induction m.
(* The trivial case *)
simpl in *; generalize (refl_equal (S n));
set (t := n) at 1; generalize (S n); subst t;
intros; destruct H0.
discriminate H.
no_set x.
(* The non trivial case *)
(* first, we simplify our hypothesis *)
revert IHm; simpl; generalize (m + 1 + n);
intros; clear n.
apply IHm with (fun y => notin (succ y)); clear IHm.
assert {m:_&m=S n0}.
exists _; auto.
destruct H0; rewrite <- e in H; generalize dependent n0.
(* now we can begin the first part of our induction,
which consists in finding an occurence of [first],
which is the exceeding element *)
induction H; intros; inversion e; clear e.
(* the trivial case is automatically solved *)
(* for the other case, we first simplify our hypothesis *)
destruct n0; [apply Nothing|];
assert (L := IHat_least n0 H3);
rewrite H3 in H; clear H3 IHat_least card.
decomp x.
(* now we can eliminate first from our set *)
assert (at_least (S n0) (fun y : Fin m => P (succ y))).
clear H1 L Q.
(* here begin the second part of the induction *)
induction H.
apply Nothing.
destruct (H2 (first m) H0); clear H0;
assert (L := IHat_least H4); clear IHat_least H4.
decomp x.
(* as we have eliminated [first] *)
destruct H3; auto.
(* but if our value is not [first] *)
apply Something with x0 (fun y : Fin m => P (succ y)); auto;
clear L H card H1.
intros; destruct (H2 _ H); clear H2 H; intuition;
rewrite H in H0; auto.
(* we finish the [first] case of the first part of the induction *)
clear L H.
assert {M : _& M = fun y : Fin m => P (succ y)}.
exists _; auto.
destruct X; rewrite <- e in H2; destruct H2.
apply Nothing.
rewrite e in *; clear e Q0; apply Something with x P0; auto;
intros; apply H3; exact (proj2 (H1 _ H4)).
(* if [first] has not yet been eliminated *)
apply Something with x0 (fun y : Fin m => P (succ y)); auto.
intros; destruct (H1 (succ y) H2).
intuition; apply H3; rewrite H5; auto.
Qed.
(** Here ends the main lemma, what follows is mainly irrelevant *)
(** Some other lemmas *)
Record bijection A B := bij
{ pi1 : A -> B;
pi2 : B -> A;
pi2pi1 : forall a, pi2 (pi1 a) = a;
pi1pi2 : forall b, pi1 (pi2 b) = b
Inductive le_set n : nat -> Set :=
| le_set_n : le_set n n
| le_set_S : forall m, le_set n m -> le_set n (S m).
Inductive Fin2 m : Set :=
Inf : forall n, le_set (S n) m -> Fin2 m.
Definition noset2 (f : Fin2 0) : SFalse :=
match f with
| Inf n l =>
match l in (le_set _ n0) return (n0 = 0 -> SFalse) with
| le_set_n =>
fun e : S n = 0 =>
match e in (_ = y) return not_nul y
with
| refl_equal => tt
end
| le_set_S m _ =>
fun e : S m = 0 =>
with
| refl_equal => tt
end
end (refl_equal 0)
end.
Fixpoint Pi1 m : Fin m -> Fin2 m :=
match m as n0 return (Fin n0 -> Fin2 n0) with
| 0 => fun x : Fin 0 => match noset x return (Fin2 0) with
end
| S n0 =>
fun H : Fin (S n0) =>
match decompose H with
| Fh _ => Inf (le_set_n (S n0))
| Sh x _ => match Pi1 x with
| Inf n1 l => Inf (le_set_S l)
end
end
end.
Definition Pi2_aux r :=
fix pi2 n (u : le_set (S r) n) : Fin n :=
match u with
| le_set_n => first r
| le_set_S _ k => succ (pi2 _ k)
end.
Definition Pi2 m (fm : Fin2 m) : Fin m :=
match fm with
| Inf r l => Pi2_aux l
end.
Theorem Fin_Fin2 : forall m, bijection (Fin m) (Fin2 m).
Proof.
intro m; refine (bij (@Pi1 m) (@Pi2 m) _ _).
induction a; auto.
simpl; destruct (Pi1 a).
simpl in *; rewrite IHa; auto.
destruct b; simpl.
induction l; auto.
simpl; destruct (Pi1 (Pi2_aux l)).
inversion IHl; auto.
Qed.
Lemma depth_in_Fin2_spe : forall m (fm : Fin m),
match Pi1 fm with Inf d _ => 1 + depth fm + d = m end.
Proof.
induction fm; simpl in *; auto.
destruct (Pi1 fm).
rewrite IHfm; auto.
Qed.
Unset Implicit Arguments.
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
- Re: [Coq-Club] Mixing induction and coinduction, Cedric Auger
- Re: [Coq-Club] Mixing induction and coinduction, Adam Chlipala
