- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Mixing induction and coinduction
- Date: Mon, 14 Sep 2009 11:30:24 -0400
Cedric Auger wrote:
muad a écrit :
My proof of this Fin injectivity is the culmination of about 500 line scriptI just did one of less than 200 loc (but the very specific part is about 130 loc):
using pigeonhole principle, I assume you have something similar?
Here's another solution of just under 200 lines. In my opinion, it's much more readable; every theorem is proved by a single tactic.
Require Import Eqdep List Omega.
Set Implicit Arguments.
Inductive fin : nat -> Type :=
| FO : forall n, fin (S n)
| FS : forall n, fin n -> fin (S n).
Implicit Arguments FO [n].
Definition cardLe (T : Type) (n : nat) :=
exists ls, length ls = n
/\ forall x : T, In x ls.
Fixpoint buildAll (n : nat) : list (fin n) :=
match n return list (fin n) with
| O => nil
| S n' => FO :: map (@FS _) (buildAll n')
end.
Hint Rewrite map_length : fin.
Ltac t' := try subst; simpl in *; intuition.
Lemma in_map_inv : forall A B (f : A -> B) x ls,
In x (map f ls)
-> exists y, x = f y /\ In y ls.
induction ls; t'; firstorder; eauto.
Qed.
Implicit Arguments in_map_inv [A B f x ls].
Lemma FS_inv : forall n (f1 f2 : fin n),
FS f1 = FS f2
-> f1 = f2.
injection 1; intro Heq; apply (inj_pair2 _ _ _ _ _ Heq).
Qed.
Ltac t := t'; repeat progress (autorewrite with fin in *;
repeat match goal with
| [ |- context[if ?E then _ else _] ] => destruct E
| [ _ : context[if ?E then _ else _] |- _ ] => destruct E
| [ H : In _ (map _ _) |- _ ] => destruct (in_map_inv H); clear H
| [ H : FS _ = FS _ |- _ ] => generalize (FS_inv H); clear H
end;
t'); eauto.
Lemma buildAll_length : forall n, length (buildAll n) = n.
induction n; t.
Qed.
Hint Rewrite buildAll_length : fin.
Hint Resolve in_map.
Lemma buildAll_full : forall n f, In f (buildAll n).
induction f; t.
Qed.
Hint Resolve buildAll_length buildAll_full.
Hint Unfold cardLe.
Theorem fin_cardLe : forall n, cardLe (fin n) n.
eauto.
Qed.
Definition fin_dest : forall n (f : fin (S n)),
{ f' : _ | f = FS f'} + { f = FO }.
exact (fun n f =>
match f in fin n' return match n' return fin n' -> Set with
| O => fun _ => unit
| S n => fun f => { f' : _ | f = FS f'} + { f = FO }
end f with
| FO _ => inright _ (refl_equal _)
| FS _ f' => inleft _ (exist _ f' (refl_equal _))
end).
Qed.
Hint Extern 1 False => discriminate.
Hint Extern 1 (_ <> _) => discriminate.
Lemma FS_eq' : forall n (f1 f2 : fin n),
(f1 = f2 -> False)
-> FS f1 = FS f2 -> False.
t.
Qed.
Hint Resolve FS_eq'.
Lemma FS_eq : forall n (f1 f2 : fin n),
{f1 = f2} + {f1 <> f2}
-> {FS f1 = FS f2} + {FS f1 <> FS f2}.
intuition; subst; intuition eauto.
Qed.
Hint Resolve FS_eq.
Definition fin_eq : forall n (f1 f2 : fin n), {f1 = f2} + {f1 <> f2}.
induction f1; intro f2; destruct (fin_dest f2) as [[? ?] | ?]; subst; auto.
Qed.
Fixpoint remove n (f : fin n) (fs : list (fin n)) {struct fs} : list (fin n) :=
match fs with
| nil => nil
| f' :: fs => if fin_eq f' f then remove f fs else f' :: remove f fs
end.
Fixpoint diff n (fs1 fs2 : list (fin n)) {struct fs2} : list (fin n) :=
match fs2 with
| nil => fs1
| f :: fs2 => remove f (diff fs1 fs2)
end.
Fixpoint dupFree n (fs : list (fin n)) {struct fs} : Prop :=
match fs with
| nil => True
| f :: fs => ~In f fs /\ dupFree fs
end.
Lemma buildAll_dupFree' : forall n (fs : list (fin n)),
dupFree fs
-> dupFree (map (@FS _) fs).
induction fs; t.
Qed.
Hint Resolve buildAll_dupFree'.
Theorem buildAll_dupFree : forall n, dupFree (buildAll n).
induction n; t.
Qed.
Hint Resolve buildAll_dupFree.
Lemma remove_not_there : forall n (f : fin n) fs,
(In f fs -> False)
-> length (remove f fs) = length fs.
induction fs; t.
Qed.
Hint Rewrite remove_not_there using assumption : fin.
Lemma remove_length : forall n (f : fin n) fs,
dupFree fs
-> length (remove f fs) >= pred (length fs).
induction fs; t.
Qed.
Hint Resolve remove_length.
Lemma In_remove : forall n (f f' : fin n) fs,
In f (remove f' fs)
-> In f fs.
induction fs; t.
Qed.
Hint Resolve In_remove.
Lemma remove_dupFree : forall n (f : fin n) fs,
dupFree fs
-> dupFree (remove f fs).
induction fs; t.
Qed.
Hint Resolve remove_dupFree.
Lemma diff_dupFree : forall n (fs1 fs2 : list (fin n)),
dupFree fs1
-> dupFree (diff fs1 fs2).
induction fs2; t.
Qed.
Hint Resolve diff_dupFree.
Lemma pred_S : forall n m1 m2,
n >= pred (m1 - m2)
-> n >= m1 - S m2.
t.
Qed.
Hint Resolve pred_S.
Theorem diff_length : forall n (fs1 fs2 : list (fin n)),
dupFree fs1
-> length (diff fs1 fs2) >= length fs1 - length fs2.
induction fs2; t;
match goal with
| [ |- context[remove ?f (diff ?fs1 ?fs2)] ] =>
elim (remove_length f (diff fs1 fs2)); t
end.
Qed.
Hint Resolve diff_length.
Lemma length_pos : forall A (ls : list A) n,
length ls >= n
-> n > 0
-> exists x, In x ls.
destruct ls; t; elimtype False; omega.
Qed.
Implicit Arguments length_pos [A ls n].
Lemma In_remove' : forall n (f : fin n) fs,
In f (remove f fs)
-> False.
induction fs; t.
Qed.
Hint Resolve In_remove'.
Lemma In_diff : forall n (f : fin n) fs1 fs2,
In f (diff fs1 fs2)
-> In f fs2
-> False.
induction fs2; t.
Qed.
Hint Resolve In_diff.
Theorem fin_cardGt : forall n m,
m > n
-> ~cardLe (fin m) n.
unfold cardLe, not; firstorder;
match goal with
| [ ls : list (fin _) |- _ ] =>
assert (Hge : length (diff (buildAll m) ls) >= length (buildAll m) - length ls); auto;
match goal with
| [ H : _ = _ |- _ ] => rewrite H in Hge
end; t; destruct (length_pos Hge); t
end.
Qed.
Hint Extern 1 (_ > _) => omega.
Theorem fin_inj : forall n m, fin n = fin m -> n = m.
intros; destruct (eq_nat_dec n m); t; destruct (le_lt_dec n m); t; elimtype False;
match goal with
| [ n : nat, m : nat, H : fin _ = fin _ |- _ ] =>
solve [ generalize (fin_cardLe n); generalize (@fin_cardGt n m); rewrite H; t ]
end.
Qed.
- Re: [Coq-Club] Mixing induction and coinduction, Cedric Auger
- Re: [Coq-Club] Mixing induction and coinduction, Adam Chlipala
