- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Apply argument to fix-expression
- Date: Sat, 19 Sep 2009 14:13:16 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=hoH9QoTyYRYPXfG+EsXqNQFMiccu1g/VOZXLcm2cy+cazhE0sqS4xKj3DuiqxWsWgN upJJm1y2J6UqYzxoNswLN5LNL2TV4BgEpTv0OnLtXMGRhoffah1kxeT/hlybbpegX+td /iONiMfR2YMuBxW/+3MP7wk577KIWU/YslYrA=
Hi everybody,
I've run into a situation, similar to the situation below. Basically,
I would like to tell Coq to apply the argument l to the
fix-expression. The match-expression would then become
match nth 2 l 7 with ...
which could be rewritten using H and then simplified. What to do?
best regards
Andreas Lundblad
------ Coq Script: -----------------
Require Import List.
Theorem test :
forall l,
nth 2 l 7 = 0 ->
0 = ((fix func (l0: list nat) :=
match nth 2 l0 7 with
| 0 => 0
| _ => 1
end) l).
Proof.
intros.
------ RESULTING STATE: ------------
1 subgoal
l : list nat
H : nth 2 l 7 = 0
0 =
(fix func (l0 : list nat) : nat :=
| 0 => 0
| S _ => 1
end) l
- [Coq-Club] Apply argument to fix-expression, Andreas Lundblad
- Re: [Coq-Club] Apply argument to fix-expression,
Adam Chlipala
Andreas Lundblad
- Re: [Coq-Club] Apply argument to fix-expression, Stéphane Glondu
Andreas Lundblad
Adam Chlipala
