- To: Coq Mailing List <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Apply argument to fix-expression
- Date: Sat, 19 Sep 2009 14:57:00 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=S3hzIe6ffE/JeRJSLCwBEC/oFVy9qh4Z6lEDpGtIs1qrAP6qNmNXRtVtTsL3VWIoBu wHkBOqX24jevgkgfvFWQf+1/Ckqig6iONruFcyJRkw1PaSfFhLEyVXCAmZry3Qr9/n9R rQAdyLTFRfk8KZS4qi9MxRCdlKAGvR0IuvdWU=
Rewriting it as a [fun] worked fine. Thanks.
My original problem was actually not on lists, but on a data type with
a large number of constructors. I didn't want to use [destruct] since
it generated a lot of cases, which I thought was completely
unnecessary since the required fact ([nth 2 l 7] in the above case)
was independent of the constructor.
Best regards,
Andreas Lundblad
- [Coq-Club] Apply argument to fix-expression, Andreas Lundblad
- Re: [Coq-Club] Apply argument to fix-expression,
Adam Chlipala
- Re: [Coq-Club] Apply argument to fix-expression, Andreas Lundblad
- Re: [Coq-Club] Apply argument to fix-expression, Stéphane Glondu
Adam Chlipala
