coq-club - Re: [Coq-Club] another inductive types question
chronological Thread
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] another inductive types question
  • Date: Sun, 11 Oct 2009 22:25:52 +0300
Hello, Vladimir.
It's easy to grasp the meaning of the error if you clearly understand the syntax of "Inductive". Consider
 Inductive ST1:Type := nat : ST1 .
This declaration binds the name "ST1" to a newly generated inductive data type. Also it binds "nat" to the only *data constructor* of "ST1". (By the way, this "nat" has zero arguments.)
But "nat" was defined in the "Coq.Init.Datatypes" ("Coq.Init" files are included silently) earlier, you've *redefined* a quite standard name. So I guess that using "nat" here is a mistake. I see a similar problem in the second line
 Inductive ST2:Type  := ST1:ST2 .
where you bind "ST1" which is *already bound* in the first line. Why redefining of names from other files is allowed but from the current file is not... I don't think it's important.
Vladimir Voevodsky wrote:
I am just trying to understand how the "Inductive" works. I also tried the following:
and the first line compiles while both lines together do not, with the message "Error: ST1 already exists".
Is it right?
Best regards,
 Roman Beslik.
