- To: André Hirschowitz <ah AT unice.fr>, "Coq Club" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] an inductive types question
- Date: Sun, 11 Oct 2009 19:20:36 +0200
- Organization: ProVal
Le Sun, 11 Oct 2009 18:58:02 +0200, André Hirschowitz <ah AT unice.fr> a écrit:
The intended meaning is
Variable Ztwo: Type.
Variable ZtwoO: Ztwo.
Variable ZtwoS: Ztwo ->Ztwo.
Hypothesis Z2axiom : forall n : Ztwo , ZtwoS (ZtwoS n) =n.
Ok, all that is well typed.
This is not yet problematic. But we want to know more:
- at first that these assumptions are "consistent" and also
-some initiality, which will warrant (essential) uniqueness.
"Consistency" should be given by a model, you don't have to bother with it.
What is initiality? Well-foundness?
Here initiality means something like
"a function from Ztwo to another Type T is given by a term v of type T (for ZtwoO)
and a term r : T ->T satisfying forall x \in T, r(r x)=x.".
Initiality should be witnessed by Coq constructions extending Case and Fixpoint. In order to be correct, these new constructions should generate proof obligations. May-be this generation could be (slighty?) problematic.
I don't understand initiality
For me all what you have to do is:
Record F2:=
{ Ztwo : Set;
ZtwoO : Ztwo;
ZtwoS : Ztwo -> Ztwo;
Ztwo_spe : forall n : Ztwo , ZtwoS (ZtwoS n) =n;
and
Definition proj (T : Set) (v : T) (r : T -> T) (correct_r : forall x, r (r x) = x) :=
Build_F2 T v r correct r.
(same as proj := Build_F2)
or
Record morphism (S1 S2 : F2) :=
{ pi : S1.(Ztwo) -> S2.(Ztwo);
piO : pi S1.(ZtwoO) = S2.(ZtwoO);
piS : forall x, pi (S1.(ZtwoS) x) = S2.(ZtwoS) (pi x)
It may be also not so easy to identify a good class of "allowed" axioms (for instance
ZtwoO \neq ZtwoO should be rejected).
It is just model dependent...
You can as well make ZtwoO \neq ZtwoO in your hypothesis, but
you simply won't be able to instantiate Ztwo; so you keep sound
ah
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Utilisant le client e-mail révolutionnaire d'Opera : http://www.opera.com/mail/
- [Coq-Club] another question (Prop as a subtype of Set), (continued)
- [Coq-Club] another question (Prop as a subtype of Set), Vladimir Voevodsky
- [Coq-Club] another question (cont.), Vladimir Voevodsky
- Re: [Coq-Club] another question (cont.), Taral
- [Coq-Club] About extraction and mutual recursion, AUGER Cédric
- [Coq-Club] Typo on coq manual, AUGER
- Re: [Coq-Club] Typo on coq manual, Pierre Letouzey
- Re: [Coq-Club] another question (Prop as a subtype of Set), Matthieu Sozeau
- Re: [Coq-Club] an inductive types question, Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question, AUGER Cédric
- Re: [Coq-Club] an inductive types question, André Hirschowitz
- [Coq-Club] another inductive types question, Vladimir Voevodsky
- Re: [Coq-Club] another inductive types question, AUGER Cédric
- Re: [Coq-Club] another inductive types question, Roman Beslik
- Re: [Coq-Club] another inductive types question, Vladimir Voevodsky
- Re: [Coq-Club] Type hierarchy, Randy Pollack
