coq-club - Re: [Coq-Club] Parametricity in Mutual Inductive Types
chronological Thread
  • To: roconnor AT theorem.ca, "Coq Club" <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Parametricity in Mutual Inductive Types
  • Date: Fri, 16 Oct 2009 22:49:14 +0200
  • Organization: ProVal
(* find '--' patterns for my replies *)
(* According to the Coq manual,
 mutually defined inductive types
 must have the same parameters for all inductive definitions.
  Is this restriction fundamental,
 or is there only to simplify the implemenation? *)
(*-- It is fundamental, but as you did below, we can have dependent types,
  which accepts different parameters,
 and dealing is not as easy as with non dependent types *)
(* I'll try to give a simplified example of
 where I want to have mutually defined
 inductive definitions with different parameters below.
  I have a real example in mind for the definion of
 a type for the syntax of a moderately complex language. *)
(* Consider the type family of silly trees: *)
Inductive SillyTree : bool -> Type :=
 | leaf : SillyTree true
 | node : forall b, SillyTree b -> SillyTree b -> SillyTree false.
(* I want to be able to pattern match on my silly trees like in the following: *)
Definition sillyFunction (st:SillyTree false) : bool :=
match st with
| node a leaf leaf => a
| _ => false
end.
(* The above works all fine.
  But now I want to capture the pair of
 SillyTrees occuring in the node constructor as
 its own type, because I want to reuse this notion in many places.
  I try to make a mutual inductive type: *)
 | node : forall b, SillyTreePair b -> SillyTree false
with SillyTreePair (b:bool) : Type :=
 | stp : SillyTree b -> SillyTree b -> SillyTreePair b.
but this fails because the type parameters are not all the same in the different defintions.
One attempted solution is to make SillyTreePair a family:
with SillyTreePair : bool -> Type :=
 | stp : forall b, SillyTree b -> SillyTree b -> SillyTreePair b.
(*-- And what about: *)
 | node : SillyTreePair -> SillyTree false
with SillyTreePair : Type :=
 | stp : forall b, SillyTree b -> SillyTree b -> SillyTreePair.
however, there is a problem. When pattern matting we get a new pattern variable bound:
Definition isMyTree (st:SillyTree false) : bool :=
match st with
| node a (stp b leaf leaf) => a (* a must equal b,
                              but pattern matching forces us to
                              provide a new pattern variable b *)
| _ => false
end.
(* This new variable b must always be equal to a;
 however we do not get such a proof when doing normal pattern matching. *)
match st with
| node (stp b leaf leaf) => b (* a must equal b,
| _ => false
end.
(* Another attempt is to use the existing product type
 to capture this pair as one object. *)
 | node : forall b, (SillyTree b * SillyTree b) -> SillyTree false.
(*-- that is what I did upper but in a non embedded structure, so you can use it
 separetely *)
(* Definition isMyTree (st:SillyTree false) : bool :=
match st with
| node a (pair leaf leaf) => a
| _ => false
end.
This works, but we no longer get our own type for (SillyTree b * SillyTree b). In particular, I want to define coercions from SillyTreePairs, but now I cannot do it because I'm using the general prod type.
I could define my own pair type:
Inductive TreePair (A : Type) : Type := treePair : A -> A -> TreePair A.
but I have to make it polymorphic.
I have no way to make it only hold SillyTrees like I want it to be restricted to.
(* Hope it helped,
Cedric *)
