coq-club - Re: [Coq-Club] Parametricity in Mutual Inductive Types
chronological Thread
  • From: Christine Paulin <Christine.Paulin AT lri.fr>
  • To: roconnor AT theorem.ca
  • Cc: muad <muad.dib.space AT gmail.com>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Parametricity in Mutual Inductive Types
  • Date: Tue, 20 Oct 2009 20:37:48 +0200
Just a comment on this subject:
Until quite recently, the rule for an argument A to be a parameter of an inductive definition Ind was that any instance of Ind in the type of a constructor either as argument or in the conclusion should be applied to A.
The spirit was that the inductive definition was made in the context of the variable A and then discharged. Also for the induction principle, this is a condition for A to be treated as a parameter. This was the reason for mutual inductive definitions to share the same parameters.
Then, taking advantadge of the separation Fix/Match (versus a general induction principle) the condition for parameters was relaxed such that Ind in the arguments of constructors could be freely instantiated. Here the idea was that Ind could have been be defined as an indexed family and then the "parametric" pattern-matching is derivable (although we need to keep the indexed family view for the induction principle).
The derived principle is nice in principle but in order to use it you have to give up the pattern-matching notation.
So I do not see any major theoretical reason to reject mutual inductive definitions with different set of parameters. It is just a bit of work to change the implementation consistently.
Christine
 wrote:
On Sat, 17 Oct 2009, muad wrote:
I feel like I might still not understand exactly what is needed, but perhaps
this is a solution?
Inductive SillyTreePair SillyTree (b:bool) : Type :=
| stp : SillyTree b -> SillyTree b -> SillyTreePair SillyTree b.
Inductive SillyTree : bool -> Type :=
| leaf : SillyTree true
| node : forall b, SillyTreePair SillyTree b -> SillyTree false.
Definition sillyFunction (st:SillyTree false) : bool :=
 match st with
   | node a (stp leaf leaf) => a
   | _ => false
 end.
SillyTree is making use of the fact that SillyTreePair f b is a strictly
positive operator in f.
Yes this works, and is a varient of what I had in mind for my very last possible solution that I didn't write out in detail. It is just a little sad that SillyTreePair ends up being polymorphic in the SillyTree parameter, which means another parameter needs to be passed everywhere.
I would probably rename your SillyTreePair as preSillyTreePair and then define (prehaps a notation) SillyTreePair := preSillyTreePair SillyTree.
Perhaps this is the best compromise, but it still isn't as nice as what you can express in Agda.
