coq-club - Re: [Coq-Club] eval compute rule
chronological Thread
  • To: Flávio Leonardo Cavalcanti d e Moura <flaviomoura AT unb.br>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] eval compute rule
  • Date: Mon, 19 Oct 2009 19:58:22 +0200
  • Organization: ProVal
Le Mon, 19 Oct 2009 19:41:46 +0200, Flávio Leonardo Cavalcanti de Moura <flaviomoura AT unb.br> a écrit:
Hi,
 I am building an exercise in proposicional logic for undergraduate
students. I defined a recursive function to propagate negations over
conjunctions and disjunction (de Morgan laws) and to eliminate double
negations. Here is the function:
 Function nnf (t:fprop) {measure flength t}: fprop :=
  match t with
    | neg(neg F) => nnf F
    | con F G => con (nnf F) (nnf G)
    | dis F G => dis (nnf F) (nnf G)
    | neg(con F G) => dis (nnf (neg F)) (nnf (neg G))
    | neg(dis F G) => con (nnf (neg F)) (nnf (neg G))
    | _ => t
  end.
The type fprop is inductive. The proof of termination of nnf is simple;
when I try to use "Eval compute" to run some examples the reduction is
not performed...
When I try
Eval compute in (nnf(neg(con (var "p") (var "q")))).
I get
  = let (v, _) := nnf_terminate (neg (con (var "p") (var "q"))) in v
     : fprop
What should I do in order to get (dis (neg (var "p")) (neg (var "q")))?
I never use Function, but in your case as compute doesn't unfold nnf_terminate,
I assume you defined it opaque (with a Qed somewhere); try to define it
transparently (with Saved or Defined), and it should be ok I think
Thanks in advance,
Flavio.
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
