- To: Sunil Kothari <skothari AT uwyo.edu>
- Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Functional Induction tactic being experimental
- Date: Wed, 21 Oct 2009 11:29:59 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type; b=V7JF+Q8GTU7e+AHBYTtcm2dWYtA32+r4Z0I7oK7kWtd4soR+76vjkAn7iVYKCFhRpE oOymMTevyI5id64QDCB0vhRe+wvaOKZtv3/XLRg8W2Ve8QZ+gp3Iew3+Ch7HcAHSx5Tl mAV/qLLqY0WzGfAux/12CWscNysbCegdhx0vQ=
Function and functional induction are marked as experimental because it may be reimplemented in the next two years. However its semantic should not change much in the case that it already deals with. In this sense we could have removed the word "experimental" from the documentation. You can use it with no worry. I encourage you to do so and to report bugs/needs.
However this feature has some limitations, mainly on dependently typed functions, that we hope to work on during the next months/years. In this sense this feature is still in development.
Hope this helps,
Pierre Courtieu
2009/10/20 Sunil Kothari <skothari AT uwyo.edu>
Hi,
Could some one explain why the Coq manual (v 8.2 and earlier) describes the functional induction tactic as "experimental" ? I would appreciate any papers/pointers at the issues involved in using this tactic.
Thanks,
Sunil
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Functional Induction tactic being experimental, Sunil Kothari
- Re: [Coq-Club] Functional Induction tactic being experimental, Pierre Courtieu
