- To: Edsko de Vries <edskodevries AT gmail.com>
- Cc: "coq-club" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Ordinal induction
- Date: Thu, 22 Oct 2009 14:24:40 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=FAr5QARUlMtVWnI5M+kkbZgo6AVDvRGWxeetzq0MKu7DJmk++faJKipuUikyseRfCu xVoqhBIfidm6pCzLwIBruuJTnNAl4VgCtyTjeL2KCQ2fW3t1Gv9xP/2clqn6PoQ5f4W6 Bmq1mz9ymNBgE6mJzaNJD2At2MglweCxqHqZU=
On Thursday 22 October 2009 9:50:18 am Edsko de Vries wrote:
> Thank you for your extensive answer. Much appreciated. The link to Dan
> Piponi's blog post was also very helpful. I think I have a better
> understanding of ordinals now.
Incidentally, while googling for Brouwer ordinal (which is, apparently, the
formulation I talked about), I came across this short paper which looks
pretty
interesting:
http://www.cs.nott.ac.uk/~pgh/nc.ps
It centers around the idea that you can keep extending my O:
O₀ = 1 + O₀ = ℕ
O₁ = O₀ + (O₀ → O₁)
O₂ = O₁ + (O₁ → O₂)
where these are all intended to be inductive fixed points. So now we have a ℕ-
indexed series of ordinal encodings. Can we build an O-indexed one? We can:
O_α = Σ β<α O_β ~ O_(lim f) = Σ n:ℕ O_(f n)
So now we have an O-indexed series of ordinal encodings, and O = O₁. Can we
have an O₂ indexed series? And so on. It also turns out you can use a
modified
(for convenience) W-type constructor to express the above series. If I
understand correctly, it's:
W A T = Z | S (W A T) | Sup (x:A) (T x -> W A T)
O_i = W (Fin i) (n ↦ O_n)
for i : ℕ, at least, where 'Fin i' is the finite set with i elements (in the
case of i = 0, n ↦ O_n is intended to be the empty function, since Fin 0 is
empty). The author ties all this together with an inductive-recursive
definition of a type On, which in some sense represents the union of an On-
indexed series of ordinal representations. Ordinal arithmetic can be defined
almost identically to arithmetic on O in my previous message.
I'm not really sure how much further this goes in modeling the behavior of
the
ordinals. However, it still doesn't get you coinduction-like behavior (I'm
pretty sure). The inductive case for a limit ordinal still represents a
choice
to progress to some unbounded but well-founded and lesser value(s). So even
though we have ordinals that live unions of ordinal-indexed families, each
particular ordinal can be seen as corresponding to some ultimately
terminating
procedure.
Cheers,
-- Dan
- [Coq-Club] Ordinal induction, Edsko de Vries
- Re: [Coq-Club] Ordinal induction,
Dan Doel
Edsko de Vries
- Re: [Coq-Club] Ordinal induction, Dan Doel
- Re: [Coq-Club] Ordinal induction, Edsko de Vries
Edsko de Vries
- Re: [Coq-Club] Ordinal induction, Danko Ilik
- Re: [Coq-Club] Ordinal induction, Nils Anders Danielsson
Dan Doel
