coq-club - Re: [Coq-Club] Ordinal induction
chronological Thread
  • To: Dan Doel <dan.doel AT gmail.com>
  • Cc: "coq-club" <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Ordinal induction
  • Date: Tue, 27 Oct 2009 09:38:26 +0000
Hi Dan,
Thanks for the additional reference and your explanation. I will have to take some time to study it, but I am now convinced that you are right: since the ordinals are well-founded, ordinal induction is just well-founded induction and therefore describes a terminating process.
It would be nice to see how ordinals can be used to do some (simple) proofs in Coq. While preparing a talk about ordinals for our research students (http://www.cs.tcd.ie/Edsko.de.Vries/talks/ordinals.pdf) I defined a small process language with an infinitely branching choice operator. I figured that I wouldn't be able to write an evaluator for this language in Coq because I thought that for a constructor (Sum : (nat -> Proc) -> Proc) of the language, given (Sum f), (f n) would not considered to be a subterm. Then I could do a termination proof using ordinals and then define the evaluator by transfinite recursion. But of course, it turns out that (f n) *is* considered a subterm and so the evaluator is easily definable :)
In fact, the whole reason I started looking at ordinals was a proof about modal logic and bisimulation, which Milner did by transfinite induction on the depth of the formula (which has an infinitely branching conjunction, and the depth must therefore be an ordinal). But since the depth of the trees is always finite (even if we cannot compute it without ordinals), 'ordinary' structural induction on these formulae should suffice (just like I could do structural induction on my process language). (Milner uses the depth to index the bisimulation too, so he has a separate need for it.)
Anyway, I feel a lot happier about transfinite induction now! Thanks again,
Edsko
