- Cc: "Coq Club" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Tail-recursion, Extraction, Mutual induction
- Date: Mon, 26 Oct 2009 15:48:31 +0100
- Organization: ProVal
Le Sun, 25 Oct 2009 21:34:34 +0100, AUGER Cédric <Cedric.Auger AT lri.fr> a écrit:
Hi, all; in Coq, there is currently no way for Function to produce mutually recursive functions with wf or measure, as far as I know.
For some functions, we may want to use a rev to a list to avoid stack overflows in extracted code in ocaml (I don't know if tail-recursion is meaningful for haskell/scheme).
Doing this can break mutual structural recursion.
So I explored a little this problem, and would appreciate what you think of this:
-Can it easily be generalized to be implemented by Function?
What I did seems quite hard to generalize...
-Is there a way to modify g_rec, so that it doesn't require the u parameter anymore?
Couldn't find a way to do it, but inlining g_rec_aux in g_rec with an
Eval compute works as g_rec_aux is no more extracted ...
-Is there a way to define f_rec and g_rec such that no Obj.t will be generated?
Ok, it was trivial, just had to change the f_rec parameter in g_rec_aux
I am not sure such an example would be worth an advanced tutorial, but if you are interested, write me.
Definition g_rec_aux A B : forall
(k : inductions A B)
(u : utree)
(f_rec : {u' : utree | bigger2 u u'} -> A),
forall (e : eertul), bigger1 u e -> B -> B.
Proof.
refine (fun A B k u f_rec =>
fix g_rec e :=
match e as e0 return bigger1 u e0 -> B -> B with
| F => fun _ acc => acc
| D a b => fun Hbig acc => g_rec a _ (k.(uD) (f_rec (exist _ b _)) acc)
end);
(* cleaning, avoiding non structured recursion application *)
clear g_rec e.
(* 1st proof obligation *)
exact (bigger1_bigger1 u a b Hbig).
(* 2nd proof obligation *)
exact (bigger1_bigger2 u a b Hbig).
Defined.
Definition f_rec_aux A B (k : inductions A B) : forall u, ACC u -> A.
Proof.
refine (fun A B k => fix f_rec u a :=
match a with
| ACC_intro h =>
(match u as u0 return u = u0 -> A with
| L => fun _ => k.(uL)
| N l => fun Heq => k.(uN) (g_rec_aux k u
(fun u => let (u, pi) := u in
f_rec u (h u pi))
(rev l F)
_
k.(uF))
end) (refl_equal u)
end);
clear f_rec a.
exact (bigger1_N Heq).
Defined.
(** * Finalization *)
Definition f_rec A B k u :=
(*Eval compute in*)
@f_rec_aux A B k u (utree_well_founded u).
Definition g_rec A B (k : inductions A B) :=
(*Eval compute in*)
fix g_rec e acc :=
match e with
| F => acc
| D a b => g_rec a (k.(uD) (f_rec k b) acc)
end.
(** * equations *)
(** first a simple induction principle *)
(* strangely, Scheme Equality for utree. it doesn't work here *)
Lemma g_rec_equation :
forall A B (k : inductions A B) e,
g_rec k e =
match e with
| F => fun acc => acc
| D a b => fun acc => g_rec k a (k.(uD) (f_rec k b) acc)
end.
Proof.
intros.
destruct e; simpl.
reflexivity.
reflexivity.
Qed.
Lemma f_rec_aux_irrelevant :
forall A B (k : inductions A B) u (H K : ACC u),
f_rec_aux k H =
f_rec_aux k K.
Proof.
intros A B k.
refine (fix frai u H {struct H} :=
match H with
| ACC_intro h => let rec := fun u0 H => frai u0 (h u0 H) in _
end
); assert (REC := rec); subst rec; clear frai H.
destruct u; simpl.
intro K; case_eq K; simpl; intros _ _; reflexivity.
intro K; case_eq K; simpl; intros; f_equal; generalize (uF k);
generalize (bigger1_N (refl_equal (N l))); generalize (rev l F).
induction e; simpl.
reflexivity.
intros.
rewrite IHe; clear IHe.
rewrite (REC _ _ (a u (bigger1_bigger2 (N l) e u b))); reflexivity.
Qed.
Lemma f_rec_equation :
forall A B (k : inductions A B) u,
f_rec k u =
match u with
| L => k.(uL)
| N l => k.(uN) (g_rec k (rev l F) k.(uF))
end.
Proof.
intros; unfold f_rec.
case_eq (utree_well_founded u); intros a _.
destruct u; simpl.
reflexivity.
f_equal; generalize (bigger1_N (refl_equal (N l))); simpl; generalize (uF k).
set (m := rev l F) at 2 3 4; generalize m; subst m.
induction m; simpl; intros.
reflexivity.
rewrite IHm; clear IHm.
unfold f_rec.
f_equal; f_equal.
apply f_rec_aux_irrelevant.
Qed.
Extract Inductive bool => bool [true false].
Extract Inductive lutree => "utree list" ["[]" "(::)"].
Extract Inductive eertul => "utree list" ["[]" "(::)"].
Recursive Extraction g_rec.
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Co-recursion question, Jeffrey Harris
- Re: [Coq-Club] Co-recursion question,
Yves Bertot
Jeffrey Harris
Dan Doel
- [Coq-Club] Tail-recursion, Extraction, Mutual induction,
AUGER Cédric
- Re: [Coq-Club] Tail-recursion, Extraction, Mutual induction, AUGER Cédric
AUGER Cédric
Dan Doel
Jeffrey Harris
- Re: [Coq-Club] Co-recursion question, Thorsten Altenkirch
Yves Bertot
