- To: Yves Bertot <Yves.Bertot AT sophia.inria.fr>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>, Ekaterina Komendantskaya <ek AT cs.st-andrews.ac.uk>
- Subject: Re: [Coq-Club] Co-recursion question
- Date: Sun, 25 Oct 2009 10:00:03 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=XUTvMUzI0Tas5RSRqjY/91pwQ+owHXoC71EP42sAVp3nNHDMcEyRtcmKyAGhVIncU+ H1N3gNMMBD77UMntCHXnXCdOmyN5N+9N3iCtWYfcHgjE9K2Nu0k2gAXAxWTa8tnqiIkn AGPuti+w/WNnKp4TqMHefWhNdaoBH3jxoYyoQ=
Thank you for your detailed reply.
Jeffrey
On Sun, Oct 25, 2009 at 2:48 AM, Yves Bertot <Yves.Bertot AT sophia.inria.fr> wrote:
My opinion is no. Every function from an inductive type to an inductive type defined using co-recursion could have been defined without co-recursion. Co-recursion brings in non-functional characteristics such as better use of memory and memoizing of pre-computed results, but not the possibility to model more function (in an extensional sense).Jeffrey Harris wrote:
Hello!
I apologize for the imprecise phrasing, but does anyone know if the ability
to do coinduction/corecursion in Coq expands the class of definable
functions on inductive types? For instance, is there any function from
nat->nat which is definable in Coq, but would not be definable without the
use of coinduction/corecursion? (So, perhaps, a composition of functions
f1:nat->stream and f2:stream->nat).
Thanks,
Jeffrey
The paper Ekaterina Komendantskaya and I wrote in 2008 on the subject , "Using structural recursion for Corecursion", http://hal.inria.fr/inria-00322331/en/, shows how co-recursive functions on streams can be replaced by structural recursive functions from nat. There is a particular brotherhood between nat and
stream that makes the replacement easy, but the brotherhood can be generalized in two ways.
Here a few quick thoughts,
1/ You take any declaration of a co-inductive datatype T, you add a singleton constructor "NYE" to represent "not yet explored" and you make the type inductive (call it T'). Then you can define an order on elements of this datatype, where NYE <= e for any e, and this order is a congruence with respect to all the constructors. Then elements of T are limits of increasing sequences in T'. The guardedness principle corresponds to using structural recursion while defining such an increasing sequence, with an extra constraint that every NYE constructor present in the term t_n must be replaced by another constructor in the term t_{n+1}. This forces you to define the increasing sequence in such a way that all elements of T' of size n are obtained in less than n steps. The term t_n in the sequence correspond to "what you can construct after n co-recursive calls".
2/ For every co-inductive datatype T with constructors C1 .... Cn, if each constructor Ci has type A1 -> ... -> Ap -> T -> ... -> T -> T, you can define an inductive type T' with n constructors with types
C'i : A1 -> ... -> Ap -> T'.
Then every term of T can be represented by a structurally recursive function of type list nat -> T'.
Actually, we can replace nat by any enumerated type containing more elements than the larger arity in T of the constructors Ci (what I call the arity in T is the number of T arguments of the constructor).
On a more concrete example, if we consider the following co-inductive type:
CoInductive Yt1 : Type :=
C1 : Z -> string -> Yt1 -> Yt1 -> Yt1
| C2 : bool -> Yt1 -> Yt1
| C3 : Yt1.
We define the type Yt1' in the following manner:
Inductive Yt1' : Type :=
C1' : Z -> string -> Yt1'.
| C2' : bool -> Yt1'
| C3' : Yt1'.
The corecursive value v1 defined by:
CoFixpoint v1 : Yt1 := C1 3 "hello" C3 v1.
can be represented by the function
Fixpoint v1' (p : list nat) : Yt1' :=
match p with
nil => C1' 3 "hello"
| 0::p' => C3'
| 1::p' => v1' p'
end.
However, the same term v1 is also represented by the following different function:
match p with
| 0::p' => match p with nil => C3' | _ => C2' true end
| 1::p' => v1' p'
end.
In the case of Streams, the type of paths can be reduced to the type list unit, because the maximal arity is one.
and list unit is isomorphic to nat. Also, there is only one constructor, with only one non-Stream component, so
that the type Stream' would be an inductive type with only one constructor that has only one component, thus isomorphic to the type of values carried in the stream. This is why we use functions of type nat -> A in the paper with Ekaterina, where we show the procedure to transform every stream value into a structurally recursive function.
The use of dependent types for the constructors adds more complications, but still I believe that they don't add more on the co-inductive side than on the inductive side.
Yves
- [Coq-Club] Co-recursion question, Jeffrey Harris
- Re: [Coq-Club] Co-recursion question,
Yves Bertot
- Re: [Coq-Club] Co-recursion question, Jeffrey Harris
Dan Doel
- [Coq-Club] Tail-recursion, Extraction, Mutual induction,
AUGER Cédric
- Re: [Coq-Club] Tail-recursion, Extraction, Mutual induction, AUGER Cédric
AUGER Cédric
Dan Doel
- Re: [Coq-Club] Co-recursion question, Thorsten Altenkirch
Yves Bertot
