coq-club - Re: [Coq-Club] Modules and Inductive types
chronological Thread
  • To: Christian Doczkal <doczkal AT ps.uni-sb.de>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Modules and Inductive types
  • Date: Wed, 9 Dec 2009 16:47:58 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :cc:content-type; b=AWKMjRJrZBVKGwphHiJsxG8JScHg4V1VNXb2QO+X5QD8+0hw6sjB097jY+qgM/WCG7 K8tecyhkwIkg2uvBB8Gw7/9gAf7hCDY9MRNZA+zcZzU8sqs0XE1fqCjtAPr+0KlGzQ2p xIWtVBx0/cu8csFA7TevBJdp/KoCZGLgXXtnU=
  Hi Christian,
  Try:
Module Type S.
 Parameter X : Type.
End S.
Module False : S.
 Inductive XX := .
 Definition X := XX.
End False.
  That's what the hint was trying to tell you, I think.
  Cheers,
  Adam
On Wed, Dec 9, 2009 at 16:36, Christian Doczkal <doczkal AT ps.uni-sb.de> wrote:
I just stumbled across the following:
Module Type S.
 Parameter X : Type.
End S.
Module False : S.
 Inductive X := .
End False.
(* Error: The kernel does not recognize yet that a parameter can be
instantiated by an inductive type. Hint: you can rename the inductive
type and give a definition to map the old name to the new name. *)
(* Of course one can circumvent the problem like this, but it removes a
lot of the structuring effect one would like Modules to have ...
Inductive FalseT : Type := .
Module FT : S.
 Definition X := FalseT.
 Definition R := @eq FalseT.
End FT.
Is there any work being done on the subject?
Are there any theoretical issues?
Regards
Christian Doczkal
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Adam Koprowski   [http://www.cs.ru.nl/~Adam.Koprowski]
R&D @ MLstate    [15 rue Berlier, 75013 Paris, France]
