coq-club - Re: [Coq-Club] Modules and Inductive types
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Modules and Inductive types
  • Date: Wed, 09 Dec 2009 17:33:21 +0100
  • Organization: ProVal
Le Wed, 09 Dec 2009 16:36:27 +0100, Christian Doczkal <doczkal AT ps.uni-sb.de> a écrit:
I just stumbled across the following:
Module Type S.
  Parameter X : Type.
End S.
Module False : S.
  Inductive X := .
End False.
(* Error: The kernel does not recognize yet that a parameter can be
instantiated by an inductive type. Hint: you can rename the inductive
type and give a definition to map the old name to the new name. *)
(* Of course one can circumvent the problem like this, but it removes a
lot of the structuring effect one would like Modules to have ...
Inductive FalseT : Type := .
Module FT : S.
  Definition X := FalseT.
  Definition R := @eq FalseT.
End FT.
Is there any work being done on the subject?
Are there any theoretical issues?
I agree with you that the False module should be accepted;
about the structuring, it is not clear that it is really a problem.
 Module FT : S.
 End FT.
Note that you won't be able to acces the R field... as it doesn't appear in the signature of S.
If you want to know the structure of X outside FT (for your structuring problems), use rather:
Module FT : S with Definition X := FalseT.
End FT.
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
