- To: Adam Chlipala <adamc AT hcoop.net>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Fixpoint decreasing parameter:help
- Date: Wed, 13 Jan 2010 21:59:11 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=gnq4R+6FDIzMjQq7AXlWHxtRlU7i66KbV9o7+4oQVughg+X8s1unI0G7jJvl1dwqFw K0aCehmL05gQdc1jt0hP3S8066RoZugI+AV6f0ChGGi2jxpju1O9z30yxsorBLvDzvv5 yogRI8WNb54YQwcCxl0iBjXYkA2WeUhhLDhSs=
On Wed, Jan 13, 2010 at 7:11 PM, Adam Chlipala
wrote:
> Groleo Marius wrote:
>> Fixpoint loop ( woff roff :Z )(n:Z) :=
>> match n with
>> | 0 => 0
>> | n' => loop 1 1 (Zminus n' 1)
>> end.
>> Error: Cannot guess decreasing argument of fix.
>> Can you point me please to some documents regarding this construct ?
> I think [Fixpoint] is well enough documented in the Coq manual, but there is
> a fundamental problem with your definition. Coq will only accept
> terminating programs, and your function loops forever when [n] is negative.
Indeed, Fixpoint is well documented in Coq'Art too; my problem wasn't
Fixpoint itself,
but as I said, the whole construct. I wasn't able to find other
examples of using other types than nat;
I tried using the same pattern as in nat, using the succesor
constructor for Z, Zsucc,
but it didn't worked, neither the Zpos,Zneg.
Regards, Groleo!
- [Coq-Club] Fixpoint decreasing parameter:help, Groleo Marius
- Re: [Coq-Club] Fixpoint decreasing parameter:help,
Adam Chlipala
- Re: [Coq-Club] Fixpoint decreasing parameter:help, Groleo Marius
Adam Koprowski
Adam Chlipala
