coq-club - [Coq-Club] Re: [Agda] Agda with the excluded middle is inconsistent ?
chronological Thread
  • To: Andreas Abel <andreas.abel AT ifi.lmu.de>
  • Cc: Chung Kil Hur <ckh25 AT cam.ac.uk>, coq-club AT inria.fr, Agda mailing list <agda AT lists.chalmers.se>
  • Subject: [Coq-Club] Re: [Agda] Agda with the excluded middle is inconsistent ?
  • Date: Wed, 13 Jan 2010 19:22:25 +0000
I agree we are in desperate need for a practical semantics for inductive families.
Not sure what practical means but what is the problem with the one in our LICS paper?
http://www.cs.nott.ac.uk/~txa/publ/ICont.pdf
With regard to what the criteria should be for legal data types or legal injective data types, I did not fully understand your proposal. The reason why parameters to data types (as opposed to indices) can be arbitrarily large is that in a "Section" (Coq- terminology) with
 Hypothesis X : very_large_type.
 data List : Set where
one can close the section and abstract over all hypotheses, including X, which will be added as a parameter to List:
 data List (X : very_large_type) : Set
Thus, example J is not accepted by accident. The ability to abstract freely is crucial. It does not lead to inconsistencies since the typing of constructors ensures that elements of X are never stored in Lists.
Surely, Vec
 data Vec (A : Set) : Nat -> Set where
   vnil  : Vec A zero
   vcons : A -> Vec A n -> Vec A (suc n)
should be injective in both arguments, but I would not deduce this from size considerations. In this case it holds even if Vec would be just a definition
 Vec A zero    = 1
 Vec A (suc n) = A * Vec n
because the cartesian product is injective.
How do you prove that cartesian product is injective? Or List?
Cheers,
Thorsten
Inferring injectivity from the definition is a very conservative approach, and you may have a more liberal proposal in mind which I would be interested to learn more about. Yet, I do not think it can be realized with the predicativity restriction, since Set and Set -> Set are both part of the same universe Set1, hence, need to be distinguished otherwise in order to separate the good (Vec) from the bad (I, J). Probably that size check would be more like the positivity test for data types.
Cheers,
Andreas
P.S.:  I would have expected that
 data I : (Set -> Set) -> Set where
is not even a well-formed inductive family in Agda, since the index (Set -> Set) is too large. But since there are no constructors, it goes through...
Chung Kil Hur a écrit :
----- Original Message ----- From: "Andrew Pitts" <Andrew.Pitts AT cl.cam.ac.uk >
To: "Agda mailing list"
Cc: "Andrew M Pitts"
<andrew.pitts AT cl.cam.ac.uk>
Sent: Sunday, January 10, 2010 3:34 PM
Subject: Re: [Agda] Agda with the excluded middle is inconsistent ?
I have been following this thread with interest. What is needed most
is a simple yet expressive (and fixed!) core type theory with an
easily understandable (by users) semantics: we should not have to
"discover" the _logical_ consequences of  an implementation---it's a
bit like saying the meaning of my programming language is given by my
compiler.
The rest of this message is speculation without reference to such a
semantics. :-)
Personally, my bet is that the version of Agda2 that allows one to
prove that type constructors are injective up to intensional equality
is inconsistent, without  the need for any form of excluded middle
postulate.
I say this not because I think that the injectivity up to intensional
equality of type constructors is in itself contradictory---indeed I
believe it is quite a natural property to ask for....so long as the
universe in which the type constructor is valued is sufficiently
large. For example, in the presence of injectivity, allowing Set to
contain a (Set -> Set)-indexed family of mutually distinct names for
the empty set
seems dangerous because Set is "too small"; whereas allowing it in Set1
data I1 : (Set -> Set) -> Set1 where
seems uncontentious. So I would advocate applying the same
predicativity/size considerations to (injective) type constructors as
Agda currently applies to data constructors. Another example: Agda2
allows
data J (f : Set -> Set) : Set where
  unit : J f
almost by accident, since it doesn't allow
data K : (f : Set -> Set) -> Set where
  unit :  (f : Set -> Set) -> K f
because of predicativity restrictions on data constructors. I would
prefer to rule out both declarations while still allowing injective
type constructors like
data J1 (f : Set -> Set) : Set1 where
  unit : J1 f
or
data K1 : (f : Set -> Set) -> Set1 where
  unit :  (f : Set -> Set) -> K1 f
Best wishes,
Andy
Hi, I agree with Andy and I think the injectivity of type constructors is useful.
As long as Andy's idea, or a similar idea, is proven to be consistent, that can be used in reasoning about heterogeneous equality.
There are two well-known notions of heterogeneous equalitay: JMeq and eq_dep.
The definitions are as follows:
Inductive JMeq (A:Set) (a:A) : forall (B : Set), B -> Prop :=
  | refljm : JMeq A a A a .
Inductive eq_dep (U:Set) (Sig: U -> Set) (x: U) (a: Sig x) : forall (y : U), Sig y -> Prop :=
 | refldep : eq_dep U Sig x a x a .
Now, assume that you have the following heterogeneous eqaulities.
(1) JMeq (Vector n) l (Vector m) l' (2) eq_dep nat Vector n l m l' From (1), you can get the equation
    Vector n = Vector m
but, not n = m as you don't have the injectivity of Vector.
On the contrary, from (2), you can get the equation
    n = m
So, without the injectivity of Vector, the equation (1) does not have the same information as the equation (2).
But, the notion of JMeq is more homogeneous, general and convinient than that of eq_dep.
So, if you can enusre that some of your type constructors are injective, you can freely use JMeq instead of eq_dep for the data types.
Indeed, I have developed a library, called Heq, to support reasoning about heterogeneous (or, extensional) equality in Coq ,and going to be officially released in a few days.
This library basically supports both the notions of JMeq and eq_dep, but in a different uniform way.
For JMeq, if you add the injectivity of your type constructors to the database, the proof search engine uses the information.
Without the injectivity, the proof search engine does not do anything useful for JMeq.
The reason why I support for JMeq (though the extra code I added for supporting JMeq is several lines) is that I believed the injectivity until I find the inconsistency.
Anway, if we can somehow add the injectivity of some inductive type constructors, it is a quite useful thing for reasoning about heterogeneous equality.
Best wishes,
Chung-Kil Hur
Preuves, Programmes et Systèmes
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
Andreas Abel  <><      Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
http://www.tcs.informatik.uni-muenchen.de/~abel/
Agda mailing list
