- To: <coq-club AT inria.fr>
- Subject: [Coq-Club] Announcing Heq 0.9 : automation for heterogeneous equality
- Date: Mon, 18 Jan 2010 23:11:40 +0100
Dear coq-users, I have developed a library, called Heq, to support
reasoning about heterogeneous equality.
It includes a detailed tutorial. Please have a
look.
If you have any questions or comments, please don't
hasitate to contact me at ( gil AT pps DOT jussieu DOT fr ).
Heq is a library supporting
- rewriting for heterogeneous equality; and
- manipulation of casts. We take equality of dependent pairs as a notion of
heterogeneous
equality, which is equivalent to eq_dep but has some advantages over it. Heq library only assumes Streicher's Axiom K, which is
planned to be
interalized in a later version of Coq. The goal of Heq is to make as little as possible the
overhead of
reasoning about heterogeneous equality. The slogan is - reasoning about heterogeneous equality as if it is a
leibniz equality.
As an example, we turned the Coq standard library for List
(about 2000
lines) into a library for Vector in a few hours without understanding the proofs, \ie, by chaning the syntax and adding some extra tactics to manipulate casts (this overhead is almost zero). Indeed, the definitions, functions and proof structures of List and Vector are almost identical. We also turned the Hugo Herbelin's merge sort of List and
its
correctness into a merge sort of Vector and its correctness in the same way. (The proof scripts are almost identical.) We also supports deeply dependent types, like
heterogeneous vector
'vectorH' of type vectorH : forall (U:Type) (P:U -> Type) (n : nat),
vector U n -> Type
In the tutorial, we will see how to reason about vectors,
matrices,
heterogeneous vectors and matrices using Heq. Note: we also simplified the strongly-typed formalization
of system F [1]
using the Heq library, and formalized the proof of strong normalization of system F given in the book 'proofs and types' [2]. [1] Nick Benton, Chung-Kil Hur, Andrew Kennedy and Conor
McBride.
Strongly typed term representations in Coq. Submitted, 2009. [2] Jean Y. Girard, Paul Taylor, Yves Lafont.
Proofs and Types. Cambridge University Press, 1989. Note: we have developed a complete, simple and fast
algorithm (tactic)
to find dependent occurrences of a term C in a term T, which plays a key role in this work. Note: if we assume the injectivity of inductive type
constructors, we
can use JMeq instead of Heq, but we have shown that in general it is inconsistent with the law of excluded middle, or the existence of impredicative type like Prop (see Agda and Coq-Club mailing list). Acknowledgement: we are very grateful to Hugo Herbelin for
many useful
discussions. ----------------
Thanks,
Chung-Kil Hur
Laboratoire Preuves Programmes Systemes CNRS & Universite Paris Diderot |
- [Coq-Club] Announcing Heq 0.9 : automation for heterogeneous equality, Chung Kil Hur
