coq-club - [Coq-Club] [Agda] Agda with excluded middle is inconsistent
chronological Thread
  • From: "Chung Kil Hur" <Chung-Kil.Hur AT pps.jussieu.fr>
  • To: "Agda mailing list" <agda AT lists.chalmers.se>, <coq-club AT inria.fr>
  • Cc:
  • Subject: [Coq-Club] [Agda] Agda with excluded middle is inconsistent
  • Date: Thu, 7 Jan 2010 00:44:06 +0100
  • List-archive: <http://lists.chalmers.se/pipermail/agda>
  • List-id: Agda implementors and users group <agda.lists.chalmers.se>
  • Resent-date: Tue, 19 Jan 2010 15:53:21 +0100
  • Resent-from: Hugo Herbelin <Hugo.Herbelin AT inria.fr>
  • Resent-message-id: <20100119145321.GI17061 AT pirogue.inria.fr>
  • Resent-to: coq-club AT inria.fr
Hi everyone,
I proved the absurdity in Agda assuming the excluded middle.
Is it a well-known fact ?
It seems that Agda's set theory is weird.
This comes from the injectivity of inductive type constructors.
The proof sketch is as follows.
Define a family of inductive type
data I : (Set -> Set) -> Set where
with no constructors.
By injectivity of type constructors, I can show that I : (Set -> Set) -> Set is injective.
As you may see, there is a size problem with this injectivity.
So, I just used the cantor's diagonalization to derive absurdity in a classical way.
Does anyone know whether cantor's diagonalization essentially needs the classical axiom, or can be done intuitionistically ?
If the latter is true, then Agda system is inconsistent.
Please have a look at the Agda code below.
Any comments are wellcome.
Best regards,
Chung-Kil Hur
============== Agda code ===============
module cantor where
  data Empty : Set where
  data One : Set where
    one : One
  data coprod (A : Set1) (B : Set1) : Set1 where
    inl : ¢£ (a : A) -> coprod A B
    inr : ¢£ (b : B) -> coprod A B
  postulate exmid : ¢£ (A : Set1) -> coprod A (A -> Empty)
  data Eq1 {A : Set1} (x : A) : A -> Set1 where
    refleq1 : Eq1 x x
  cast : ¢£ { A B } -> Eq1 A B -> A -> B
  cast refleq1 a = a
  Eq1cong : ¢£ {f g : Set -> Set} a -> Eq1 f g -> Eq1 (f a) (g a)
  Eq1cong a refleq1 = refleq1
  Eq1sym : ¢£ {A : Set1} { x y : A } -> Eq1 x y -> Eq1 y x
  Eq1sym refleq1 = refleq1
  Eq1trans : ¢£ {A : Set1} { x y z : A } -> Eq1 x y -> Eq1 y z -> Eq1 x z
  Eq1trans refleq1 refleq1 = refleq1
  Iinj : ¢£ { x y : Set -> Set } -> Eq1 (I x) (I y) -> Eq1 x y
  Iinj refleq1 = refleq1
  data invimageI (a : Set) : Set1 where
    invelmtI : forall x -> (Eq1 (I x) a) -> invimageI a
  J : Set -> (Set -> Set)
  J a with exmid (invimageI a)
  J a | inl (invelmtI x y) = x
  J a | inr b = ¥ë x ¡æ Empty
  data invimageJ (x : Set -> Set) : Set1 where
    invelmtJ : forall a -> (Eq1 (J a) x) -> invimageJ x
  IJIeqI : ¢£ x -> Eq1 (I (J (I x))) (I x)
  IJIeqI x with exmid (invimageI (I x))
  IJIeqI x | inl (invelmtI x' y) = y
  IJIeqI x | inr b with b (invelmtI x refleq1)
  IJIeqI x | inr b | ()
  J_srj : ¢£ (x : Set -> Set) -> invimageJ x
  J_srj x = invelmtJ (I x) (Iinj (IJIeqI x))
  cantor : Set -> Set
  cantor a with exmid (Eq1 (J a a) Empty)
  cantor a | inl a' = One
  cantor a | inr b = Empty
  OneNeqEmpty : Eq1 One Empty -> Empty
  OneNeqEmpty p = cast p one
  cantorone : ¢£ a -> Eq1 (J a a) Empty -> Eq1 (cantor a) One
  cantorone a p with exmid (Eq1 (J a a) Empty)
  cantorone a p | inl a' = refleq1
  cantorone a p | inr b with b p
  cantorone a p | inr b | ()
  cantorempty : ¢£ a -> (Eq1 (J a a) Empty -> Empty) -> Eq1 (cantor a) Empty
  cantorempty a p with exmid (Eq1 (J a a) Empty)
  cantorempty a p | inl a' with p a'
  cantorempty a p | inl a' | ()
  cantorempty a p | inr b = refleq1
  cantorcase : ¢£ a -> Eq1 cantor (J a) -> Empty
  cantorcase a pf with exmid (Eq1 (J a a) Empty)
  cantorcase a pf | inl a' = OneNeqEmpty (Eq1trans (Eq1trans (Eq1sym (cantorone a a')) (Eq1cong a pf)) a')
  cantorcase a pf | inr b = b (Eq1trans (Eq1sym (Eq1cong a pf)) (cantorempty a b))
  absurd : Empty
  absurd with (J_srj cantor)
  absurd | invelmtJ a y = cantorcase a (Eq1sym y)
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
