- To: David Singh <david.singh45 AT googlemail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] programing dependent types without program
- Date: Wed, 20 Jan 2010 19:32:51 +0100
Hi David,
Le 20 janv. 10 à 18:07, David Singh a écrit :
<snip/>
This can be defined as follows:
Require Import Program.Equality.
Definition pPT n I (t : T PT n) (x : EPT (P3 n) (cn I t)) : PPT x.
intros n I t x; dependent destruction x. exact (pp3 _ ).
Defined.
This is fine until one has to prove things involving pPT; the function
reduces to a large, complicated expression. I was wondering if there is a
better way to define pPT *without* the use of dependent destruction, and which
would reduce as it should?
I think this example falls outside the capabilities of Coq's match without
K/JMeq, so something like [dependent destruction] is needed. I'm working
on a plugin that gives you the equations you expect (as rewrite rules,
not primitive reductions) and an elimination principle from dependent
pattern-matching definitions.
It's currently available only through git://github.com/mattam82/Coq- Equations.git
In your case the following definition works:
Require Import Equations.
Equations(nocomp) pPT n I (t : T PT n) (x : EPT (P3 n) (cn I t)) : PPT x :=
pPT _ _ _ (p3 e') := pp3 e'.
And you get
pPT_equation_1 :
forall (n : nat) (t : PT n) (ts : T PT n) (e : EPT t ts), pPT (p3 e) = pp3 e
and
pPT_elim :
forall
P : forall (n : nat) (I : PT n) (t : T PT n) (x : EPT (P3 n) (cn I t)),
PPT x -> Prop,
(forall (n : nat) (t : PT n) (ts : T PT n) (e : EPT t ts),
P n t ts (p3 e) (pp3 e)) ->
P n I t x (pPT x)
Hope this helps,
-- Matthieu
- [Coq-Club] programing dependent types without program, David Singh
- Re: [Coq-Club] programing dependent types without program, Matthieu Sozeau
- Re: [Coq-Club] programing dependent types without program, Adam Chlipala
