coq-club - Re: [Coq-Club] programing dependent types without program
chronological Thread
  • To: David Singh <david.singh45 AT googlemail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] programing dependent types without program
  • Date: Thu, 21 Jan 2010 05:58:35 -0500
David Singh wrote:
  This can be defined as follows:
   Require Import Program.Equality.
    Definition pPT n I (t : T PT n) (x : EPT (P3 n) (cn I t)) : PPT x.
    intros n I t x; dependent destruction x. exact (pp3 _ ).
   Defined.
  This is fine until one has to prove things involving pPT; the function
reduces to a large, complicated expression. I was wondering if there is a
better way to define pPT *without* the use of dependent destruction, and which
  would reduce as it should?
"Better" is in the eye of the beholder, but here's an axiom-free version that reduces naturally. This was a bit of a puzzle to figure out, but I find the solution reasonably simple/modular, as these things go.
Definition Thead F n (t : T F (S n)) : F n :=
  match t in T _ n' return match n' with
                             | O => unit
                             | S n'' => F n''
                           end with
    | e => tt
    | cn _ x _ => x
  end.
Definition Ttail F n (t : T F (S n)) : T F n :=
                             | O => unit
                             | S n'' => T F n''
                           end with
    | e => tt
    | cn _ _ y => y
  end.
Lemma decomp' : forall F n (t : T F n),
  match n return T F n -> Prop with
    | O => fun _ => True
    | S n' => fun t => t = cn (Thead t) (Ttail t)
  end t.
  destruct t; trivial.
Defined.
Theorem decomp : forall F n (t : T F (S n)),
  t = cn (Thead t) (Ttail t).
  intros; exact (decomp' t).
Defined.
Definition p3inv n (pt : PT n) (t : T PT n) (x : EPT pt t) :=
  match x in EPT pt t
    return match pt in PT n return T PT n -> Type with
             | P3 _ => fun t => EPT (Thead t) (Ttail t)
             | _ => fun _ => unit
           end t with
    | p3 _ _ _ x' => x'
    | _ => tt
  end.
Lemma p3inv_same' : forall n (pt : PT n) t (x : EPT pt t),
  match pt return forall t, EPT pt t -> Prop with
| P3 _ => fun _ x => p3 (p3inv x) = match decomp _ in _ = T return EPT _ T with
                                          | refl_equal => x
                                        end
    | _ => fun _ _ => True
  end _ x.
  destruct x; trivial.
Defined.
Theorem p3inv_same : forall n (I : PT n) t (x : EPT (P3 n) (cn I t)),
  p3 (p3inv x) = x.
  intros; exact (p3inv_same' x).
Defined.
Definition pPT n I (t : T PT n) (x : EPT (P3 n) (cn I t)) : PPT x :=
  match p3inv_same x in _ = T return PPT T with
    | refl_equal => pp3 (p3inv x)
  end.
Theorem pPT_red : forall n (t : PT n) (ts : T PT n) (x : EPT t ts),
  pPT (p3 x) = pp3 x.
  reflexivity.
Qed.
