- From: Chantal Keller <chantal.keller AT wanadoo.fr>
- To: AUGER <Cedric.Auger AT lri.fr>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] User's defined conversion tactic
- Date: Fri, 22 Jan 2010 12:30:27 +0100
Thanks for your answer.
AUGER a écrit :
Le Fri, 22 Jan 2010 11:16:47 +0100, Chantal Keller <chantal.keller AT wanadoo.fr> a écrit:>>
For instance:that is not really a solution, but you can do:
Ltac foo := unfold bar; simpl.
Eval foo in foobar.
Eval cbv beta iota zeta delta [bar] in foobar.
This would perhaps work in this particular example, but I would like to be able to make a succession of unfold and simpl. Moreover,
would make too much computation.
As conversions may have a special status, not to add new constructions,
a rather clean hack may be to allow this kind of programmation:
"Definition bar := nat.
(*Ltac foo := cbv delta [bar].*)
Tactic Notation "'foo'" := (cbv delta [bar]).
Eval foo in bar."
So that foo is just unfolded and behaves like:
Eval cbv delta [bar] in bar."
Yes, it would be nice to have facilities to define new conversions in Coq.
Chantal.
- [Coq-Club] User's defined conversion tactic, Chantal Keller
- Re: [Coq-Club] User's defined conversion tactic,
AUGER
- Re: [Coq-Club] User's defined conversion tactic, Chantal Keller
AUGER
