- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Is Coq being too conservative?
- Date: Fri, 22 Jan 2010 13:38:25 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=luWX/xWnaCiNxKYjQWcira3u83sLxUmgNQLKF3m/n4nbgrrpU6mJnoX1PCWUX8m3K7 ehQHWHGN+gPR/WSi0vAq0ph6myIEPvaC67A6CGuxXkfYce1y1yEfVnUP6Js/03y7+vPd MADIcGnf+Fsm1dxUM66V+to6hVoAK3NNZwX+k=
Hello Jef,
2010/1/22 Jeff Terrell
<jeff AT kc.com>:
> Many thanks for your comments. Unfortunately, this problem is a show stopper
> for my project. Does anyone know if there's a prototypical implementation of
> Coq that would allow f to pass the guardedness checker?
The development below more or less does this. It first makes a
coinductive type that is bigger than what you need, then restricts
that by introducing a predicate, creating a version of f that lives in
the bigger coinductive set and finally defines a new ff that is more
or less equivalent to your f, I don't know if this can be used in your
particular case but it might be a start. Note that my implementation
is horrendously code-duplicated. Generally one would want to turn the
types A and X into some abstract data type to avoid this.
Good luck,
Chris
CoInductive A: Set
:= | Build_A : A_list -> A
with A_list: Set
:= | cons_A: A -> A_list -> A_list
| nil_A: A_list.
Inductive A_list_finite: A_list -> Prop
:= | nil_A_finite: A_list_finite nil_A
| cons_A_finite:
forall a: A,
forall l: A_list,
A_list_finite l ->
A_list_finite (cons_A a l).
CoInductive A_lists_finite: A -> Prop
:= | Build_A_finite:
forall l: A_list,
A_list_and_children_finite l ->
A_lists_finite (Build_A l)
with A_list_and_children_finite: A_list -> Prop
:= | Build_A_finite_nil:
A_list_and_children_finite nil_A
| Build_A_finite_cons:
forall a: A,
forall l: A_list,
A_lists_finite a ->
A_list_finite l ->
A_list_and_children_finite (cons_A a l).
Inductive AA: Set
:= mk_AA: forall a: A, A_lists_finite a -> AA.
CoInductive X : Set
:= | Build_X : X_list -> X
with X_list: Set
:= | cons_X: X -> X_list -> X_list
| nil_X: X_list.
Theorem X_unfold:
forall x: X,
x = match x with
| Build_X l => Build_X l
end.
Proof.
intro x.
case x.
tauto.
Qed.
Theorem X_list_unfold:
forall l: X_list,
l = match l with
| cons_X x l => cons_X x l
| nil_X => nil_X
end.
Proof.
intro l.
case l; tauto.
Qed.
Inductive X_list_finite: X_list -> Prop
:= | nil_X_finite: X_list_finite nil_X
| cons_X_finite:
forall a: X,
forall l: X_list,
X_list_finite l ->
X_list_finite (cons_X a l).
CoInductive X_lists_finite: X -> Prop
:= | Build_X_finite:
forall l: X_list,
X_list_and_children_finite l ->
X_lists_finite (Build_X l)
with X_list_and_children_finite: X_list -> Prop
:= | Build_X_finite_nil:
X_list_and_children_finite nil_X
| Build_X_finite_cons:
forall a: X,
forall l: X_list,
X_lists_finite a ->
X_list_finite l ->
X_list_and_children_finite (cons_X a l).
Inductive XX: Set
:= mk_XX: forall x: X, X_lists_finite x -> XX.
CoFixpoint f (a: A): X
:= match a with
| Build_A l => Build_X (f_list l)
end
with f_list (l: A_list): X_list
:= match l with
| cons_A a l => cons_X (f a) (f_list l)
| nil_A => nil_X
end.
Theorem f_list_conserves_list_finite:
forall l: A_list,
A_list_finite l ->
X_list_finite (f_list l).
Proof.
intros l H1.
induction H1 as [|a l H1 IH];
rewrite X_list_unfold;
simpl;
[apply nil_X_finite; fail|].
apply cons_X_finite.
assumption.
Qed.
Theorem f_conserves_lists_finite:
forall a: A,
forall H1: A_lists_finite a,
X_lists_finite (f a).
refine (
cofix f_conserves_lists_finite (a: A) (H1: A_lists_finite a):
:= match H1 with
| Build_A_finite l H2 => _
end
with f_conserves_lists_finite_list (l: A_list)
(H1: A_list_and_children_finite l):
X_list_and_children_finite (f_list l)
:= match H1 with
| Build_A_finite_nil => _
| Build_A_finite_cons a l H2 H3 H4 => _
end
for f_conserves_lists_finite).
(* Build_A_finite *)
rewrite X_unfold.
simpl.
apply Build_X_finite.
apply f_conserves_lists_finite_list.
assumption.
rewrite X_list_unfold.
simpl.
apply Build_X_finite_nil.
(* Build_A_finite_cons *)
simpl.
apply Build_X_finite_cons;
[apply f_conserves_lists_finite
|apply f_list_conserves_list_finite
|apply f_conserves_lists_finite_list];
assumption.
Qed.
Definition ff (a: AA): XX.
intros [a H1].
apply (mk_XX (f a)).
apply f_conserves_lists_finite.
assumption.
Defined.
- [Coq-Club] Is Coq being too conservative?, Jeff Terrell
- Re: [Coq-Club] Is Coq being too conservative?, AUGER
- Message not available
- Re: [Type-Based Guardednees Checking] Re: [Coq-Club] Is Coq being too conservative?,
Jeff Terrell
- Re: [Coq-Club] Is Coq being too conservative?, Chris Dams
- Re: [Type-Based Guardednees Checking] Re: [Coq-Club] Is Coq being too conservative?, Adam Chlipala
Jeff Terrell
