- From: Guilhem Moulin <guilhem.moulin AT ens-lyon.org>
- To: geng chen <chengeng4001 AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] A question about pattern matching
- Date: Fri, 22 Jan 2010 15:52:18 +0100
Hello,
On Fri, 22 Jan 2010 at 22:41:13 +0800, geng chen wrote:
> I've met a problem about pattern matching. for example there is a
> function:
> Definition check_a (a : nat) : bool :=
> match a with
> 1 => true
> | _ => false
> end.
> and result of check_a is "true". So how can I prove that a = 1 ?
> It is important for me. Could any one help me?
I'd try to do some case analysis on `a' :
Lemma check_a_1: forall a, check_a a = true -> a=1.
Proof.
intros a H.
do 2 (destruct a; try discriminate).
trivial.
Qed.
Hope this helps,
Guilhem.
signature.asc
Description: Digital signature
- [Coq-Club] A question about pattern matching, geng chen
- Re: [Coq-Club] A question about pattern matching, Guilhem Moulin
- Re: [Coq-Club] A question about pattern matching, Chantal Keller
