- To: Eugene Kirpichov <ekirpichov AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] A strangely unaccepted mutually inductive definition
- Date: Sat, 23 Jan 2010 12:40:03 -0500
Eugene Kirpichov wrote:
Inductive btree (t:Set) :=
| BLeaf : t -> btree t
| BNode : btree t -> btree t -> btree t.
Inductive trexp : Set :=
| TLeaf : nat -> trexp
| TNode : btree trexp -> trexp.
Fixpoint total (t:trexp) :=
match t with
| TLeaf n => n
| TNode b => btotal b
end
with btotal (b:btree trexp) :=
match b with
| BLeaf t => total t (* An error here? *)
| BNode b1 b2 => btotal b1 + btotal b2
end.
I get the following error...
This program is rejected for the same reason that the first version of [nat_tree_ind'] is rejected in the chapter where you got the exercise (on page 55). Recursion over nested inductive types needs to be implemented with nested recursion, not mutual recursion. It's a hard-coded restriction; I'm not aware of any intuition behind it.
- [Coq-Club] A strangely unaccepted mutually inductive definition, Eugene Kirpichov
- Re: [Coq-Club] A strangely unaccepted mutually inductive definition, Adam Chlipala
- Re: [Coq-Club] A strangely unaccepted mutually inductive definition, Eugene Kirpichov
