coq-club - Re: [Coq-Club] A strangely unaccepted mutually inductive definition
chronological Thread
  • To: Adam Chlipala <adamc AT hcoop.net>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] A strangely unaccepted mutually inductive definition
  • Date: Sun, 24 Jan 2010 11:09:16 +0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=KpRrpyvk6+UwaXjW7C5rNl3RLQTGWHAFTzc7sQwMI5OwPBtGG22D9Z1cBClrWdJxGq XeeqCaNpk+ZyESkKsrYpAWCpjUBJoMfjd7jyiUUcm/qbFxACFvb5m02ydx2QaHW4QHfE y2Zfj8lQVPDdoscDogwUirkmAI5rxmCthCstA=
2010/1/23 Adam Chlipala
<adamc AT hcoop.net>:
> Eugene Kirpichov wrote:
>> Inductive btree (t:Set) :=
>>  | BLeaf : t ->  btree t
>>  | BNode : btree t ->  btree t ->  btree t.
>> Inductive trexp : Set :=
>>  | TLeaf : nat ->  trexp
>>  | TNode : btree trexp ->  trexp.
>> Fixpoint total (t:trexp) :=
>>  match t with
>>  | TLeaf n =>  n
>>  | TNode b =>  btotal b
>>  end
>> with btotal (b:btree trexp) :=
>>  match b with
>>  | BLeaf t =>  total t (* An error here? *)
>>  | BNode b1 b2 =>  btotal b1 + btotal b2
>>  end.
>> I get the following error...
> This program is rejected for the same reason that the first version of
> [nat_tree_ind'] is rejected in the chapter where you got the exercise (on
> page 55).  Recursion over nested inductive types needs to be implemented
> with nested recursion, not mutual recursion.  It's a hard-coded restriction;
> I'm not aware of any intuition behind it.
Oh yes, indeed, thanks! By the time I solved the preceding exercises I
already forgot about that part of text :-|
Eugene Kirpichov
Web IR developer, market.yandex.ru
