- From: "Lehner Hermann" <hermann.lehner AT inf.ethz.ch>
- To: "Coq Club" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Inductive Definitions and Positive Occurrences
- Date: Sun, 24 Jan 2010 09:33:37 +0100
Dear Coq-Club
It seems that i've simplified my example a little bit too much. Here is a
different version, from which i derived the latter example:
I've got three inductive definitions that depend on each other. I choose to
define two of them together by using 'with', and to define a third one later
in the development and pass it as parameter v outside section 'sec'.
Coq claims that Ind2 is not used strictly positive.
I'd be very grateful for any explanations of this behavior. Thanks!
Section sec.
Variable v : Prop.
Inductive Ind1 : Prop :=
| a: v -> Ind1
| b: Ind3 -> Ind1
with Ind3 : Prop :=
| c: Ind1 -> Ind3.
End sec.
Inductive Ind2: Prop :=
| d: Ind1 Ind2 -> Ind2.
-----Original Message-----
[mailto:hermann.lehner AT inf.ethz.ch]
Sent: Fri 22.01.2010 14:40
To: Coq Club
Subject: [Coq-Club] Inductive Definitions and Positive Occurrences (again)
Dear all,
There were already some discussions about similar issues, however, I
can't explain the following.
I'm aware that the example doesn't make sense, but it shows the essence
of a problem that i've got in a development of mine of a much larger scale.
(* The following doesn't work (Coq 8.2pl1) *)
Inductive i1 (t : Type) :=
with i2 (t : Type) :=.
Inductive i3 :=
| def: i1 i3 -> i3.
Here, I get a "Non strictly positive occurence" Error.
The following similar constructs work fine, and I can't see the
conceptual difference.
(* This works *)
Inductive i1 (t : Type) := .
Inductive i3 :=
| def: i1 i3 -> i3.
(* This works too *)
Inductive i1 :=
with i2 :=
with i3 :=
| d: i1 -> i3.
Anyone a clue? Thank!
Hermann
http://www.pm.inf.ethz.ch/people/lehnerh
- [Coq-Club] Inductive Definitions and Positive Occurrences (again), Hermann Lehner
- RE: [Coq-Club] Inductive Definitions and Positive Occurrences, Lehner Hermann
