coq-club - Re: [Coq-Club] Non structural recursive functions
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: "Flavio L. C. de Moura" <flaviomoura AT unb.br>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Non structural recursive functions
  • Date: Thu, 28 Jan 2010 20:46:49 +0100
Hello,
 It is possible to use the lemma quotient_equation generated by the
Function definition:
Require Import Recdef.
Require Import Arith.
Function quotient (a b: nat) {measure (fun x => x) a} : nat :=
  match a,b with
    | _,0 => 0
    | 0,_ => 0
    | _,_ => match (nat_compare a b) with
               | Gt => S(quotient (a - b) b)
               | Lt => 0
               | Eq => 1
                 end
  end.
intros a b n H n0 H1 H2.
assert (S n > S n0).
generalize H2; clear H2.
apply <- nat_compare_gt.
apply lt_minus.
auto with arith.
auto with arith.
Defined.
Check quotient_ind.
Theorem triv1 : forall a:nat, quotient (S a) (S a) = 1.
Proof.
  intro a;rewrite quotient_equation.
  SearchAbout nat_compare.
  replace (nat_compare (S a) (S a) )with Eq.
  auto.
  induction a;simpl;auto.
  rewrite nat_compare_S;auto.
Qed.
Pierre
Quoting "Flavio L. C. de Moura"
<flaviomoura AT unb.br>:
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi there,
  I defined a simple (but not structurally) recursive function, but I am
not able to play with it, and I would like to understand why...  The
function is
  match a,b with
    | _,0 => 0
    | 0,_ => 0
               | Lt => 0
               | Eq => 1
                 end
  end.
apply lt_minus.
auto with arith.
auto with arith.
Defined.
And I would like to proof the following:
Proof.
  induction a.
I didn't manage to go further from now on:  quotient 1 1 = 1.
Why simpl doesn't apply the definition of quotient? I also tried to
defined other variations of this function but I get stuck at the very
same point... For instance, I also tried the following:
Program Fixpoint quotient (a b: nat) {measure (fun x => x) a} : nat :=
  match a with
    | 0 => 0
    | S n => match b with
               | 0 => 0
               | S m => if (le_gt_dec m n) then S (quotient (n - m) (S m))
                     else 0
             end
  end.
Obligation 1.
  omega.
Defined.
In addition, from the Coq documentation, I couldn't find a difference
between the constructions "Function" and "Program Fixpoint". Is there
any conceptual difference between them?
Thank you very much in advance!
Cheers.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkth5GwACgkQJ9M3XSenoWidngCfZOM6mgvOl4ezlVHeLpTldaG3
MosAoI4AGjKlFTHJwSWwbyYSo0OmroBq
=53qP
-----END PGP SIGNATURE-----
