coq-club - Re: [Coq-Club] Non structural recursive functions
chronological Thread
  • To: Guillaume Allais <sbleune AT gmail.com>
  • Cc: "Flavio L. C. de Moura" <flaviomoura AT unb.br>, coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Non structural recursive functions
  • Date: Thu, 28 Jan 2010 15:42:50 -0500
Le 28 janv. 10 à 14:53, Guillaume Allais a écrit :
Hi Flavio,
I think that your definitions are a bit too complicated for what you want to do. I took the second one and let Coq infer the measure (when the measure is simple, it works well).
Here is the code :
__________________________________
Fixpoint quotient (a b: nat) : nat := match a with
   | 0 => 0
   | S n => match b with
              | 0 => 0
| S m => if (le_gt_dec m n) then S (quotient (n - m) (S m)) else 0
end
end.
The system does not really infer a measure, it just checks a syntactic
guardness condition for each argument in turn. In this case it relies
on the fact that [minus] was cleverly defined as:
Fixpoint minus (n m : nat) :=
  match n with
    | 0 => n (* note n not 0 here *)
    | S k => match m with 0 => n (* n not (S k) here *)
               | S l => minus' k l
             end
  end.
If you change [n] to [0] or [n] to [S k] in these branches then the
syntactic check will be helpless when checking the definition of
quotient.
In addition, from the Coq documentation, I couldn't find a difference
between the constructions "Function" and "Program Fixpoint". Is there
any conceptual difference between them?
Function is designed to generate a fixpoint equation and the inductive
graph of the function, whereas Program mainly provides support for defining
the function. There is a theory to work with the generated well-founded
fixpoints in Program.Wf though.
Hope this clarifies things a bit,
-- Matthieu
