- To: coq-club AT inria.fr
- Cc: Pierre Courtieu <Pierre.Courtieu AT cnam.fr>, Adam Chlipala <adam AT chlipala.net>
- Subject: Re: [Coq-Club] Reset Induction Principle
- Date: Thu, 4 Mar 2010 21:30:57 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=CsldsjBaT+BLGnLaqV0iKwsSxwWX6XzqOP6az9B0KNZCf0YsaYjkGf0cio8cDN2VQ2 BD1Kaz3ZM2HEkklnLqCgPgJ4TeZ45xOgCzqtxQxzSf06QGDj7llSGrF84GHMrECUoTNa OydTGXV9rPerm2hAol5U7GMLPc8eU5p8lilJI=
This is a real pity. Adam Chlipala's online book on Certified
Programming with Dependent Types (http://adam.chlipala.net/cpdt/) uses
"Restart" and "Abort" extensively.
Wish you a great day,
Catalin
On Thu, Mar 4, 2010 at 8:38 PM, Pierre Courtieu
wrote:
> No this is not a bug. These commands are supposed to be used when
> using coq in a terminal. Using these command in coqide would
> de-synchronize the "locked region" of the buffer and coq typing
> environment. The locked region is supposed to represent at any time
> the definitions already accepted by the prover. In particular allowing
> such command would lead to situations where navigation forward would
> be impossible. For example:
> Definition X:=nat.
> (*Point 2*)
> Definition Y := X.
> Definition Z:= ....
> Reset X.
> (* Point 1*)
> Suppose the user navigates this file to point 1 and then back to
> point 2, then definition of Y is not typable since X was resetted. So
> the user is stuck.
> This may seem restrictive but I think it is a good thing that this
> kind of problem is avoided.
> However it may be interesting to wish for an option for disabling this
> restriction for people knowing what they do.
> You may use proofgeneral for that in the meantime, though I would not
> call this a feature of PG...
> Regards,
> People
> 2010/3/4
> �<catalin.hritcu AT gmail.com>:
>> Hello,
>> I have an apparently similar problem with the commands "Restart" and
>> "Abort".
>> They are accepted by coqc, but CoqIDE gives out an "Error: Use CoqIDE
>> navigation instead". "Reset" doesn't work either.
>> Is it possible that this is a CoqIDE bug?
>> Thanks,
>> Catalin
- Re: [Coq-Club] Reset Induction Principle, catalin . hritcu
Pierre Courtieu
- Re: [Coq-Club] Reset Induction Principle, Catalin Hritcu
Damien Pous
Pierre Courtieu
Adam Chlipala
- Re: [Coq-Club] Reset Induction Principle, Pierre Courtieu
Adam Chlipala
Pierre Courtieu
Pierre Courtieu
