coq-club - [Coq-Club] Inconsistency of classical logic in Coq
chronological Thread
  • From: Robbert Krebbers <robbertkrebbers AT student.ru.nl>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Inconsistency of classical logic in Coq
  • Date: Tue, 09 Mar 2010 23:17:57 +0100
Hi,
I'm wondering whether a strong version of excluded middle, em : forall P : Prop, { P } + { ~P }, still results in inconsistency in the current version of Coq. To prove inconsistency from it, I defined a retract from Prop to bool (as described in [1] for an older version of Coq), as follows.
Parameter em : forall P, { P } + { ~P }.
Definition b2P (b : bool) : Prop := match b with
| true => True
| false => False
end.
Definition P2b (P : Prop) : bool := match em P with
| left _ => true
| right _ => false
end.
Lemma P2P2 : forall P : Prop, P -> b2P (P2b P).
Proof with auto.
unfold P2b. unfold b2P. intros.
destruct (em P)...
Qed.
Lemma P2P1 : forall P : Prop, b2P (P2b P) -> P.
Proof with auto.
destruct (em P)...
contradiction.
Qed.
Now I tried to use theories/Logic/Hurkens.v to show that this yields a paradox. Unfortunately Hurkens.v requires a type bool : Prop instead of the usual bool : Set (from the Coq library). So I tried to define a boolean type in Prop as follows.
Inductive pbool : Prop := ptrue | pfalse.
This gets accepted, but elimination over inductive types in Prop is not allowed, if I attempt to define P2b for pbool (similarly as for bool) Coq gives the following message:
Error:
Incorrect elimination of "b" in the inductive type "pbool":
the return type has sort "Type" while it should be "Prop".
Elimination of an inductive object of sort Prop
is not allowed on a predicate in sort Type
because proofs can be eliminated only to build proofs.
Alternatively I tried to change bool : Prop into bool : Set in Hurkens.v, but then a lot of definitions break (obviously). Therefore I wonder whether assuming em : forall P : Prop, { P } + { ~P } still leads to inconsistency.
Robbert
[1] H. Geuvers, Inconsistency of classical logic in type theory, Short Note (Version of November 27, 2001)
