- From: Benjamin Werner <benjamin.werner AT polytechnique.org>
- To: Robbert Krebbers <robbertkrebbers AT student.ru.nl>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Inconsistency of classical logic in Coq
- Date: Tue, 9 Mar 2010 23:38:58 +0100
Hi,
No, excluded middles should not lead to inconsistencies in Coq, unless you launch Coq with the option -impredicative-set which gives you the old version of the type theory.
The current version is meant to have a model in classical set theory which validates strong excluded middles. In this model, Any Prop has atmost one element. This is what prevents the known paradoxes. In particular, your
Inductive pbool : Prop := ptrue | pfalse.
has only one element in the model which "explains" that you cannot eliminate towards a Type (which would mean discriminating between ptrue and pfalse).
With the option -impredicative-set you can replace Prop by Set in your development and it should "work".
I hope this helps.
Benjamin
Le 9 mars 10 à 23:17, Robbert Krebbers a écrit :
Hi,
I'm wondering whether a strong version of excluded middle, em : forall P : Prop, { P } + { ~P }, still results in inconsistency in the current version of Coq. To prove inconsistency from it, I defined a retract from Prop to bool (as described in [1] for an older version of Coq), as follows.
Parameter em : forall P, { P } + { ~P }.
Definition b2P (b : bool) : Prop := match b with
| true => True
| false => False
end.
Definition P2b (P : Prop) : bool := match em P with
| left _ => true
| right _ => false
end.
Lemma P2P2 : forall P : Prop, P -> b2P (P2b P).
Proof with auto.
unfold P2b. unfold b2P. intros.
destruct (em P)...
Qed.
Lemma P2P1 : forall P : Prop, b2P (P2b P) -> P.
Proof with auto.
destruct (em P)...
contradiction.
Qed.
Now I tried to use theories/Logic/Hurkens.v to show that this yields a paradox. Unfortunately Hurkens.v requires a type bool : Prop instead of the usual bool : Set (from the Coq library). So I tried to define a boolean type in Prop as follows.
This gets accepted, but elimination over inductive types in Prop is not allowed, if I attempt to define P2b for pbool (similarly as for bool) Coq gives the following message:
Error:
Incorrect elimination of "b" in the inductive type "pbool":
the return type has sort "Type" while it should be "Prop".
Elimination of an inductive object of sort Prop
is not allowed on a predicate in sort Type
because proofs can be eliminated only to build proofs.
Alternatively I tried to change bool : Prop into bool : Set in Hurkens.v, but then a lot of definitions break (obviously). Therefore I wonder whether assuming em : forall P : Prop, { P } + { ~P } still leads to inconsistency.
Robbert
[1] H. Geuvers, Inconsistency of classical logic in type theory, Short Note (Version of November 27, 2001)
- [Coq-Club] Inconsistency of classical logic in Coq, Robbert Krebbers
- Re: [Coq-Club] Inconsistency of classical logic in Coq, Benjamin Werner
- Re: [Coq-Club] Inconsistency of classical logic in Coq, AUGER
- <Possible follow-ups>
