coq-club - [Coq-Club] Set and heterogeneous lists
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Set and heterogeneous lists
  • Date: Fri, 12 Mar 2010 15:05:22 +0100
Hello
I have the following definitions:
Require Import List.
Inductive hlist : list Type -> Type :=
| hnil : hlist nil
| hcons : forall (X:Type) Xs, X ->  hlist Xs -> hlist (X::Xs).
(* Abstractly, everything works as one would expect *)
Variable Tp' : Type.
Variable Tm' : Tp' -> Type.
Variable Ts' : (list Tp').
Check (hlist (map Tm' Ts')).
(* But given concrete instances for Tp/Tm I get typing errors *)
Inductive Tp : Type := i | ar : Tp -> Tp -> Tp.
Inductive Tm : Tp -> Type :=
  Var : forall sigma:Tp, nat -> Tm sigma
| Ap : forall sigma tau:Tp,Tm (ar sigma tau) -> Tm sigma -> Tm tau.
Variable Ts : list Tp.
Check (list Tp). (* Set *)
Check (hlist (map Tm Ts)).
(* fails: The term "map Tm Ts" has type "list Set"
 while it is expected to have type "list Type". *)
Check also gives Tp:Set and Tm : Tp -> Set. (Type(0) if I set printing
for Universes) I guess this is part of the issue? What is really going
wrong here?
The second part (of course) works if I restrict hlist to "list Set".
Is there any fix that does not involve restricting hlist?
Regards
Christian
