- To: Christian Doczkal <doczkal AT ps.uni-sb.de>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Set and heterogeneous lists
- Date: Fri, 12 Mar 2010 09:40:39 -0500
Christian Doczkal wrote:
Variable Ts : list Tp.
Check (list Tp). (* Set *)
Check (hlist (map Tm Ts)).
(* fails: The term "map Tm Ts" has type "list Set"
while it is expected to have type "list Type". *)
A simple type annotation fixes this:
Check (hlist (map (B := Type) Tm Ts)).
- [Coq-Club] Set and heterogeneous lists, Christian Doczkal
- Re: [Coq-Club] Set and heterogeneous lists, Adam Chlipala
