coq-club - Re: [Coq-Club] Setoids and symmetry
chronological Thread
  • To: Robert Helgesson <robert AT rycee.net>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Setoids and symmetry
  • Date: Fri, 12 Mar 2010 10:07:14 -0500 (EST)
On Fri, 12 Mar 2010, Robert Helgesson wrote:
which is rather straight-forward until I hit precisely the problem in
my previous message, i.e., I have to show something like
 setoid_sym (setoid_sym (assoc f g h)) = assoc f g h
applying proof irrelevance does indeed do away with this equality and
subsequently makes the whole theorem pass.  Seeing the "proof
completed" fills me with giddy joy but I'm worried that introducing
the axiom in this situation is bad.  Am I worrying unnecessarily?
Adding the axiom is not believed to be inconsistent, so you are safe in that front. Adding axioms to Coq can lead to non-canonical objects. This means you can have normalized values (containing axioms) of inductive types that do not begin with a constructor. However, making opaque proof objects (ending a proof with QED) also creates non-canonical objects, because an opaque proof is almost the same thing as declaring the theorem as an axiom.
Making opaque proofs is common practice because you very rarely need to reduce proof objects. In fact, making them opaque can speed up computation because the reduction engine will specifically avoid reducing the proof objects.
So on the one hand this axioms is quite unlikely to ever cause you difficulties. On the other hand I usually find these axioms are in the end usually unnecessary, but avoiding using such axioms can complicates the proof development. As a beginner I would recommend you use your axioms as needed. When you become more experienced you can learn to make the complex proof developments needed to avoid such axioms.
I should also add that I understand that Coq will eventually be adding proof irrelevence as a theorem, though I understand that there may be a high price to pay for such luxery (undecidable type checking).
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
