- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Indexed Types Pattern Matching Problem
- Date: Mon, 22 Mar 2010 16:08:59 +0200
- Disposition-notification-to: Roman Beslik <beroal AT ukr.net>
Yes, you are right, there is a structurally smaller value. See the proof below. The answer to why your proof does not check lays in your proof term ("Show Proof."). It is huge so its analysis is a separate task.
I also assigned my names to variables because I am always lost in names auto-generated by Coq. :)
Definition to_T (a : Rep) (x : Interpret RT a) : (a = RT) -> T.
refine (fix to_T (a : Rep) (x : Interpret RT a) {struct x}: (a = RT) -> T :=
match x with
| inl a b _ => _
| inr a b x0 => _
| rec _ => _
| const _ _ => _
end
); intros; try discriminate.
(* first case: [l = (Const nat)] *) inversion H. subst a0. inversion i. exact (A X).
(* second case: [r = Rec] *)
refine (match x0 in (Interpret _ r) return (Plus a0 r = RT -> T) with
| inl a b _ => _
| inr a b _ => _
| rec x1 => _
| const _ _ => _
end
H); intros; try discriminate.
refine (to_T _ x1 (refl_equal _)).
Defined.
On 22.03.10 10:01, Gyesik Lee wrote:
Having seen that the problem setting seems to be not trivial to
handle, let me ask questions one by one.
(* the proof is finished, but termination check failed although X is
obviously structurally smaller than x. *)
Best regards,
Roman Beslik.
- [Coq-Club] Indexed Types Pattern Matching Problem, Gyesik Lee
- Re: [Coq-Club] Indexed Types Pattern Matching Problem,
Roman Beslik
Gyesik Lee
Roman Beslik
Gyesik Lee
- Re: [Coq-Club] Indexed Types Pattern Matching Problem, Roman Beslik
- Message not available
- Re: [Coq-Club] Indexed Types Pattern Matching Problem, Gyesik Lee
Gyesik Lee
Roman Beslik
Gyesik Lee
Roman Beslik
- Re: [Coq-Club] Indexed Types Pattern Matching Problem, Adam Chlipala
